Enclosure Air Filtration system May 18, 2017 08:34PM |
Re: Enclosure Air Filtration system May 19, 2017 03:03AM |
Re: Enclosure Air Filtration system May 19, 2017 04:05AM |
Re: Enclosure Air Filtration system May 19, 2017 04:20AM |
Re: Enclosure Air Filtration system May 19, 2017 04:51AM |
Re: Enclosure Air Filtration system May 19, 2017 05:05AM |
Re: Enclosure Air Filtration system May 19, 2017 05:40AM |
Re: Enclosure Air Filtration system May 19, 2017 07:08AM |
Re: Enclosure Air Filtration system May 25, 2017 01:08AM |
Re: Enclosure Air Filtration system May 25, 2017 01:40AM |
Re: Enclosure Air Filtration system May 25, 2017 03:55AM |
Re: Enclosure Air Filtration system May 25, 2017 04:17PM |
simspeed
[attachment 94536 Recirculatingfilteredairassembly.JPG]
Here is a redesign using 3" ABS pipe with two 120 mm inline case fans. The center section is clear PVC with both Hepa and Charcoal filters sitting on thin stainless rods. The center section would use quick release ring clamps to allow the disc filters to be serviced or replaced. I don't see this needing to be program controlled; just a on/off/speed manual switch should do the job don't you think? Thanks...
Re: Enclosure Air Filtration system May 26, 2017 02:39AM |
Re: Enclosure Air Filtration system May 26, 2017 07:03AM |
Re: Enclosure Air Filtration system May 26, 2017 03:18PM |
MCcarman
Now all you need to do is attach both ends to the same piece of the door or frame. Currently you have one end on the fixed top and the other on the sliding door.
Re: Enclosure Air Filtration system May 26, 2017 04:20PM |
simspeed
[attachment 94570 Recirculatingfilteredairassembly-2.JPG]
Good points fellas....thanks for pitching new ideas. I think this redesign is likely what I will go with. I'm using a larger 140mm fan and up-sizing the pipe to 4" ABS. This allows me to build reducer adapters that hold two 1/2" x 5.5" activated charcoal coffee filters above and below the fan as shown. I want to keep the quick change clamps to change these filters when needed. This also allows me to add a Hepa filter at the upper inlet to catch particulates before they get to the charcoal filters. Like DjDemonD says I can vacuum that off the screen without having to unbolt anything from inside the chamber. The inlet housings I can also build from ABS sheet rather than trying to print the more stylish but complex design from the previous drawing. Printing the reducer adapters should be pretty straight forward. The middle two will bolt directly to the fan housing and the outer two will solvent weld to the ABS pipe.
Re: Enclosure Air Filtration system May 27, 2017 01:57AM |
Re: Enclosure Air Filtration system May 27, 2017 07:55AM |
Re: Enclosure Air Filtration system May 27, 2017 07:25PM |
