Nichrome wire temperature sensing May 28, 2017 02:48PM |
Re: Nichrome wire temperature sensing May 28, 2017 04:55PM |
Re: Nichrome wire temperature sensing May 28, 2017 05:36PM |
Skrogh
I think the issue here would be that the nichrome wire will be significantly warmer, than the rest of the construction.
As you want things to heat up quickly, and heat transfers faster, the greater the temperature difference.
So reading off the temperature of the nichrome wire would not give any useful information.
Re: Nichrome wire temperature sensing May 28, 2017 06:57PM |
Re: Nichrome wire temperature sensing May 28, 2017 07:20PM |
leadinglights
The idea has possibilities but I think that nichrome is not a good candidate. Nichrome has a very high resistivity, about 120 x 10-8 Ωm this means that you don't need a lot of material to give your required resistance. Little material = little surface area = not much area to conduct the heat from the wire - the point that Skrogh made. The second point is that nichrome has quite a low temperature coefficient of resistance, 4 x 10-4/°C which means that better electronics are needed. Nickel is the best common material that I know of with a resistivity of 6.8 x 10-8 Ωm and a tempco of 6.4 x 10-3/°C.
Anodised aluminium may work as an insulator but would be likely to be too thin and some insulation would be needed between the turns of wire. A possible answer would be to use a glass frit to enamel the outside of the heated part and a second layer to insulate between the turns of wire.
Mike
Re: Nichrome wire temperature sensing May 28, 2017 07:45PM |
Re: Nichrome wire temperature sensing May 29, 2017 01:37AM |
Re: Nichrome wire temperature sensing May 29, 2017 07:37AM |
Re: Nichrome wire temperature sensing May 29, 2017 08:14AM |
Re: Nichrome wire temperature sensing May 29, 2017 09:19AM |
Re: Nichrome wire temperature sensing May 29, 2017 12:42PM |
the_digital_dentist
The OP's drawing looks a lot like the hot-ends in my CubeX Duo printer. They are not very good. I don't know if the volume for molten filament is too large or the heat zone is too long, but they drool continuously. The wire has some sort of glass fiber insulation wrapped around it, and the coils are covered with some sort of cement like substance. They commonly fail shorted to the aluminum tube. I've taken a couple of dead ones apart and it looks like they develop hot spots that burn through the glass fiber insulation and let the bare wire contact the aluminum. If they do that in a couple spots, it's all over. The thermistor leads are insulated with teflon sleeves and set in a groove in the tube, and the nichrome wire is wrapped right over them. Crazy!
In order to insulate the nichrome wire from itself and the tube, you need some sort of electrical insulator that can withstand high temperatures. But that means it's going to be a thermal insulator too. That means the wire is going to operate at a much higher temperature than the aluminum tube and plastic you're melting. The wire gets longer when it heats up (18 um/m C or so). If you wrapped it tightly around the tube when it was cold, when it heats up the coils are going to loosen, reducing the heat transfer to the tube. That is how hot spots develop. Using a short piece of heavy gauge wire would minimize that problem, but a short piece of heavy gauge wire has low resistance so you'll need to operate it at a low voltage or very high intermittent current to keep the average power at a reasonable number.
Re: Nichrome wire temperature sensing May 29, 2017 01:17PM |
Re: Nichrome wire temperature sensing May 29, 2017 04:25PM |
Re: Nichrome wire temperature sensing May 29, 2017 05:33PM |
Skrogh
If you really do want to try this approach out, why not get a commercial tubular ceramic heater?
The [deltaprintr.com] has one, but I've seen the heater type on both Aliexpress and Alibaba.
You will still face the issue of the coil being significantly warmer, than what you are trying to control the temperature of - namely the plastic in the extruder.
Re: Nichrome wire temperature sensing May 30, 2017 08:42AM |
Re: Nichrome wire temperature sensing May 30, 2017 09:58AM |
Re: Nichrome wire temperature sensing May 30, 2017 10:33AM |
Re: Nichrome wire temperature sensing May 31, 2017 04:16AM |
Skrogh
Re: Nichrome wire temperature sensing May 31, 2017 09:54PM |
Re: Nichrome wire temperature sensing June 01, 2017 05:17AM |
newbob
'heater wire' hot end is on my try-it list. I consider resistance temperature sensing a non issue - if it does not work - I'll be fine with a thermistor. Big hurtles are mechanical fixing of the heating wire to the nozzle and thermal conductivity and capacity of it. I plan on using 32 or 36Ga Kanthal (temco ire in UK?) wire attached longitudinally (S pattern) while using a combination of high temperature paint/fiberglass paper and self fusing silicone tape for keeping it firmly attached to the nozzle.
Re: Nichrome wire temperature sensing June 01, 2017 12:53PM |
leadinglights
newbob
Hi newbob,
Please don't abandon resistance temperature sensing too early. With care the junction between the wire of the heater and the metal of the hotend tube can be as low as 1.8°C per Watt and this can be mathematically quite predictable, certainly waaay simpler than the geometry of a Delta printer. If you had thought of trying resistance sensing then Kanthal is a poor choice as it has a low temperature coefficient of resistance. Many "vaping" wires are available for e.g. from "The Crazy Wire Company" in the U.K., typical of these are Nickel Iron Wire with a fairly high resistiveity and high TCo as [www.wireandstuff.co.uk] and also Nickel with a low resistiveity and high TC as [www.wireandstuff.co.uk]
Mike
