Ok, sorry about that, I have the Firmware Repetier 0.92.8...
I did the Mixing extruder theory of repetier and that worked to set the percentage of the second extruder, but now I can't use the Heater of the E2 to set the temperature.. I suppose it's because the ''Mixing extruder'' tries to use only ONE Hotend, so now I am trying to make the Second Hotend work or
If I try Ditto Printing, is there any way to change the signal of the second extruder to change the percentage?
Edited 1 time(s). Last edit at 08/04/2017 10:14PM by Vizaresh.
