M25 Requires #define SDSUPPORT enabled
Something here is wrong. My pause and resume work. and has worked in every Marlin Firmware I have used.
However I wish pause worked differently, as it pauses on the print. It would be better if pause sent nozzle off the print to location 0,0,current Z position.
Because by the time you push all the buttons to get to move x or y axis the nozzle has melted top top layer.
I have never actually needed to pause. And they have a change filament which works.
I Think if you wanted to insert some hardware inside a print the Pause would come in handy.
In the slicer software you can tell the slicer to "pause at height". Now this is better because you can "pause at height" insert your hardware and resume print.
And with other plugins and the ability to create your own.
Change bed temp at height
change filament at Z
switch extruder at height with ooze prevention
Pause at Height
ect.....
Edited 4 time(s). Last edit at 09/06/2017 12:13PM by Roberts_Clif.
