All,
Marlin: 1.1.4
Printer: CR-10 Board: Sangio
Symptoms:
Prints pause. Resulting in craters in my prints plus the added time while stalled. happens all thru out my prints.
Things I have tried. with all the same results pausing.with a simultanious message Busy: Processing
1: New USB cable
2: Print over SD card with USB disabled
3: Disable Host Keep Alive Feature
4: Tried different STL’s
Even on my starting script.
G28 ; home all axes
;G1 Y10 F1500 ; avoid binder clips
G1 Z0.2 F3000 ; get ready to prime
G92 E0 ; reset extrusion distance
G1 X120 E10 F600 ; prime nozzle
G1 X150 F5000 ; quick wipe.
At the end of the wipe. it will most always stall. for say 1-2 seconds.
Then proceed to the print. which will stall again right at the beginning. every time.
then once started? its unknown depending on the print.
Help?
TIA-Sam
Edited 1 time(s). Last edit at 09/14/2017 03:19AM by VDX.
SamR
MendelMax... (A build for ever in process... ... ... will it/ Is it ever done!?) yea, Its done alright its sitting collecting dust!
Moved onto a Creality CR-10
