nozzle filament output temperature September 28, 2017 10:59PM |
Re: nozzle filament output temperature September 28, 2017 11:13PM |
Admin Registered: 13 years ago Posts: 7,001 |
Re: nozzle filament output temperature September 30, 2017 02:49PM |
Re: nozzle filament output temperature September 30, 2017 08:40PM |
Re: nozzle filament output temperature October 02, 2017 12:52PM |
Re: nozzle filament output temperature October 02, 2017 01:59PM |
cozmicray
So you are saying to copper plate the hotend?
a thin film of copper doing all this?
What pHD in thermal dynamics has stated that this would help?
Perhaps a FLIR thermal camera to show where the polymer
is cooling too fast or is off by 0.0001 deg C
Insanity
-- set temperature +- 10 c should be OK for any polymer
Re: nozzle filament output temperature October 02, 2017 02:09PM |
Re: nozzle filament output temperature October 02, 2017 02:26PM |
leadinglights
No, not well said.
Firstly, 691175002 said "plated copper block and nozzle" from which I assume a block and nozzle made of copper and plated perhaps with nickle to stop it becoming oxidized, secondly, even if the nozzle was steel and plated with copper the copper with a conductivity of 386 w/m K versus steel with a conductivity of 36 W/m K would contribute a substantial improvement.
Learn a tiny bit of physics to back up your certainty of knowledge.
Mike
Re: nozzle filament output temperature October 02, 2017 02:40PM |
Re: nozzle filament output temperature October 02, 2017 02:46PM |
Re: nozzle filament output temperature October 02, 2017 02:59PM |
Re: nozzle filament output temperature October 02, 2017 03:46PM |
Re: nozzle filament output temperature October 02, 2017 04:10PM |
Re: nozzle filament output temperature October 03, 2017 09:44PM |
Re: nozzle filament output temperature October 04, 2017 04:22AM |
Re: nozzle filament output temperature October 04, 2017 01:42PM |
Re: nozzle filament output temperature October 04, 2017 05:34PM |
Re: nozzle filament output temperature October 05, 2017 04:40AM |
The difference between filament temp in nozzle
and the temp at the thermistor is minuscule.
So you using a filament material that you
must control temp +- 0.0001 deg C?
Re: nozzle filament output temperature October 05, 2017 10:57PM |
Re: nozzle filament output temperature October 05, 2017 11:39PM |
Re: nozzle filament output temperature October 06, 2017 02:08AM |
cozmicray
Found a good article that may show some temperature effects
on PLA, dramatic surface effects
He does state
"I also destroyed one of these vases at the time to see if the temperature made any obvious differences to bonding strength. I could not find any difference while splitting and ripping the different temperature printed areas."
the original question.
Temperature effects with PLA printing / RepRap News
[richrap.blogspot.com]
Re: nozzle filament output temperature October 06, 2017 01:08PM |
Re: nozzle filament output temperature October 06, 2017 02:05PM |
cozmicray
I'll agree that +- 10deg C does have consequences
if
you will agree:
type of PLA
manufacturer
melt length
glass temp --- melt temp
Flow rate
cooling
Have just as much effect on extruded PLA
