How to fit a thermal fuse? September 22, 2017 03:43AM |
Re: How to fit a thermal fuse? September 22, 2017 06:23AM |
Re: How to fit a thermal fuse? September 22, 2017 07:38AM |
Re: How to fit a thermal fuse? September 22, 2017 08:38AM |
Re: How to fit a thermal fuse? September 22, 2017 09:28AM |
Re: How to fit a thermal fuse? September 22, 2017 04:52PM |
Re: How to fit a thermal fuse? September 25, 2017 06:16AM |
Re: How to fit a thermal fuse? October 15, 2017 04:24PM |
Re: How to fit a thermal fuse? October 15, 2017 06:22PM |
Re: How to fit a thermal fuse? October 16, 2017 03:01AM |
Re: How to fit a thermal fuse? October 16, 2017 06:29AM |
David J
In the end I found some very small thermal fuses that are plastic-encapsulated, small and can carry 2A (I need less than 1A). Hopefully one of them will do the job nicely if I use high-temp silicone to fix it in place. There will be cork insulation & a backing plate to keep everything safe & secure.
Re: How to fit a thermal fuse? October 16, 2017 07:01AM |
Re: How to fit a thermal fuse? October 16, 2017 09:36AM |
the_digital_dentist
David J
What kind of heater uses less than 1A?
Re: How to fit a thermal fuse? October 16, 2017 09:39AM |
dc42
The thermal cutouts I bought were these [www.ebay.co.uk]. They have insulated bodies (the listing says plastic, but the ones I received are ceramic) and a convenient screw hole for attaching them to an aluminium bed plate. They are self-resetting, which means you can test them without writing them off.
Please note, the 15A rating is almost certainly for AC use, and will be much lower when used with DC.
Re: How to fit a thermal fuse? October 22, 2017 05:58AM |
