External driver for extruder
Posted by Hc
Hc
August 27, 2012 08:44PM
Where can I find the electric scheme to control the stepper motor of the extruder with the Motherboard ( v1.2) and a Stepper Motor Driver (v2.3)? I'm using in my Mendel (Gen3) the h-bridges of the Extruder Controller for this, so isn't it necessary to modify the firmware to use a external driver?
Re: External driver for extruder
August 28, 2012 01:49AM
here is a good starting place
[reprap.org]
Hc
August 30, 2012 08:47PM
Ok, thanks. It's very simple, like this scheme [www.flickr.com]. But I'm using the enable pin connected to ground, and the step and direction pins are connected with the motherboard with the SDA and SCL pins. It's working with the same firmware.
