Is it possible to print honeycombs for bees February 12, 2017 09:42AM |
Re: Is it possible to print honeycombs for bees February 12, 2017 10:07AM |
Re: Is it possible to print honeycombs for bees February 12, 2017 12:56PM |
Re: Is it possible to print honeycombs for bees February 12, 2017 01:43PM |
Re: Is it possible to print honeycombs for bees February 12, 2017 01:54PM |
Re: Is it possible to print honeycombs for bees February 12, 2017 03:42PM |
Re: Is it possible to print honeycombs for bees February 12, 2017 03:57PM |
Re: Is it possible to print honeycombs for bees February 12, 2017 04:20PM |
Re: Is it possible to print honeycombs for bees February 12, 2017 08:48PM |
Re: Is it possible to print honeycombs for bees February 13, 2017 02:31AM |
Re: Is it possible to print honeycombs for bees February 13, 2017 05:10AM |
Re: Is it possible to print honeycombs for bees February 13, 2017 06:32AM |
Re: Is it possible to print honeycombs for bees February 13, 2017 01:55PM |
Re: Is it possible to print honeycombs for bees February 13, 2017 02:09PM |
Re: Is it possible to print honeycombs for bees February 13, 2017 03:00PM |
Re: Is it possible to print honeycombs for bees February 13, 2017 03:45PM |
o_lampe
I'd like to test it in my garden for wild bees etc. Is there a chance to build a bee hive for wild bees?
Re: Is it possible to print honeycombs for bees February 13, 2017 06:17PM |
Re: Is it possible to print honeycombs for bees February 14, 2017 02:58AM |
Re: Is it possible to print honeycombs for bees February 14, 2017 03:04AM |
Re: Is it possible to print honeycombs for bees February 14, 2017 03:39AM |
Re: Is it possible to print honeycombs for bees February 14, 2017 08:05AM |
o_lampe
Would it be good enough to print a honeycomb corner and let the bees do the rest? If not, how big would it have to be?
o_lampe
The temp might be a problem with PLA, but the bees are there to keep it at a constant level and 45°C should be no problem. ( Wax does melt at ??°C )
Natural PLA almost looks like bee-wax.
o_lampe
I've created a parametric scad file to generate any size of honeycomb. Also attached a sample of a 5x5 honeycomb to play with.
The .jpg shows the dimensions like diameter and wall thickness.
The constants are in german, feel free to ask about their meaning.
o_lampe
PDBeal
My neighbor did exactly that. He found a wild bee hive in the woods behind his house. He built them a box, and sure enough they moved it. A great side affect was my fruit trees in the backyard blew up with fruit the following years since it was so close to the hive. I think he also managed to get some honey from the bees, although I think he had only build the wood box. The bees built the honeycomb.
Re: Is it possible to print honeycombs for bees February 14, 2017 05:50PM |
Re: Is it possible to print honeycombs for bees February 17, 2017 12:57PM |
SatorCodex
If one print carefully, There is possible to print smooth walls. But its hard to tell how smooth it has to bee.. winking smiley
etfrench
ABS can be smoothed with acetone to get really smooth surfaces. Baking it (or PLA) for a few hours at a temperature near the glass transition state may remove most of the volatile substances in the plastic. You could also use shellac to seal the plastic which would give you a smooth surface and would also be food safe.
Re: Is it possible to print honeycombs for bees February 17, 2017 03:52PM |
Re: Is it possible to print honeycombs for bees February 17, 2017 05:50PM |
Re: Is it possible to print honeycombs for bees February 22, 2017 10:41AM |
Re: Is it possible to print honeycombs for bees February 22, 2017 01:48PM |
Re: Is it possible to print honeycombs for bees February 26, 2017 08:20PM |
Re: Is it possible to print honeycombs for bees February 26, 2017 09:23PM |
Re: Is it possible to print honeycombs for bees February 27, 2017 12:45PM |
Admin Registered: 16 years ago Posts: 13,889 |
