PEI vs. BuildTak vs. PrintBite June 01, 2016 01:12AM |
Re: PEI vs. BuildTak vs. PrintBite June 01, 2016 03:29AM |
Re: PEI vs. BuildTak vs. PrintBite June 01, 2016 04:48AM |
Re: PEI vs. BuildTak vs. PrintBite June 01, 2016 05:01AM |
Re: PEI vs. BuildTak vs. PrintBite June 01, 2016 08:00AM |
Re: PEI vs. BuildTak vs. PrintBite June 01, 2016 08:13AM |
Re: PEI vs. BuildTak vs. PrintBite June 01, 2016 08:28AM |
Re: PEI vs. BuildTak vs. PrintBite June 01, 2016 08:42AM |
PRZ
An increased temperature for the second layer may be of benefit, but I don’t know of a slicer which does that. Sometimes, I was doing that manually.
Re: PEI vs. BuildTak vs. PrintBite June 01, 2016 03:53PM |
Re: PEI vs. BuildTak vs. PrintBite June 01, 2016 04:11PM |
Re: PEI vs. BuildTak vs. PrintBite June 01, 2016 05:15PM |
Re: PEI vs. BuildTak vs. PrintBite June 03, 2016 12:46AM |
Re: PEI vs. BuildTak vs. PrintBite June 03, 2016 12:50AM |
Re: PEI vs. BuildTak vs. PrintBite June 03, 2016 01:36AM |
DjDemonD
PRZ
Simplify3d can do this.
Re: PEI vs. BuildTak vs. PrintBite June 03, 2016 04:34PM |
etfrench
DjDemonD
PRZ
Slic3r can do this as well as modify most of the other settings. Look at the "Load Modifier" in the object properties.
Re: PEI vs. BuildTak vs. PrintBite June 03, 2016 06:19PM |
Re: PEI vs. BuildTak vs. PrintBite June 03, 2016 07:16PM |
Re: PEI vs. BuildTak vs. PrintBite June 06, 2016 10:16PM |
epicepee
It sounds like the general consensus is:
PEI is great, except for the occasional difficulty detaching.
BuildTak is like PEI (when heated; I do have a heated bed) except cheaper and easier to damage.
PrintBite does not adhere as strongly, especially to ABS.
Anyone disagree?
Re: PEI vs. BuildTak vs. PrintBite June 06, 2016 11:20PM |
Re: PEI vs. BuildTak vs. PrintBite June 06, 2016 11:45PM |
Re: PEI vs. BuildTak vs. PrintBite June 07, 2016 04:02AM |
Re: PEI vs. BuildTak vs. PrintBite June 07, 2016 05:51AM |
epicepee
Anyone disagree?
Re: PEI vs. BuildTak vs. PrintBite June 07, 2016 06:04AM |
Re: PEI vs. BuildTak vs. PrintBite June 07, 2016 09:20AM |
DjDemonD
Its a shame we can't come up with an aluminium backing plate for these surfaces which is flat (to a reasonable tolerance) and onto which each of the surfaces can come bonded. This can then be clipped to the printer, printed upon and then removed with ease or swapped for another surface when required. It seems PEI and Printbite both have their uses, differences in method of operation and differences in cost, what's difficult is the need to effectively permanently bond them to your print bed (aluminium is much better for this than a layer of insulating glass between the chosen surface and heatbed), meaning that swapping surfaces is difficult.
Re: PEI vs. BuildTak vs. PrintBite October 31, 2017 12:42AM |
DjDemonD
That's a nice print, but in my experience a hollow model is the least likely to lift at the corners, its the infill that generates the lateral contraction forces that lift the corners of long narrow parts. Circular models with low/no infill is not such a risk for lifting. Try printing Angus from maker's muse Warpinator 5000 its a real test. I can get it to stick on printbite which I have dialled in quite well, almost the whole part stays stuck down but around 10mm lifts at each end. It is a fierce test of adhesion though.
[attachment 79375 warpinator5000.stl]
Re: PEI vs. BuildTak vs. PrintBite October 31, 2017 03:03AM |
Re: PEI vs. BuildTak vs. PrintBite November 01, 2017 01:50PM |
Re: PEI vs. BuildTak vs. PrintBite November 01, 2017 03:41PM |
Re: PEI vs. BuildTak vs. PrintBite November 02, 2017 08:30AM |
Re: PEI vs. BuildTak vs. PrintBite November 02, 2017 12:52PM |
