runaway temps
Posted by skaha
runaway temps
May 25, 2018 03:40PM
Hi guys, where would you start to find problem of runaway temps on both the bed and the extruder, the temps are set for 55c on the bed, 200c on extruder, when I call for heat they both continue on past set temps until they reach max temp and then shut off. The printer is a prusi clone with Marlin 1.0.(DMYDP model P802MA).
Thanks for any help offered.
Terry
Re: runaway temps
May 25, 2018 07:53PM
Your PID settings probably, since by the sounds of things your thermistor and heaters are working fine.
Re: runaway temps
May 25, 2018 09:40PM
Thanks for the reply Trakyan, thats a start point for me. BIG learning curve.
Terry
Re: runaway temps
May 26, 2018 02:27AM
That's his PID settings for the extruder. Nothing wrong IMHO.
echotongue sticking out smileyID settings:
echo: M301 P22.20 I1.08 D114.00
When the bed runs into overtemp shutdown while set to 55°C, the MosFet probably doesn't switch off.
Did you inspect the controller for bad solder joints or cracked tracks on the PCB?
Edited 1 time(s). Last edit at 05/26/2018 02:27AM by o_lampe.
