Why RepRap is failing August 04, 2008 01:56AM |
Re: Why RepRap is failing August 04, 2008 03:48AM |
What does Linux have, 3%? And actually declining, according to some estimates
But moving swiftly on.Quote
RepRap is failing. Designs diverge further from the standard on a daily basis
Nophead has been getting brilliant results ... So then why hasn
Edited 1 time(s). Last edit at 08/04/2008 03:50AM by Ru.
Re: Why RepRap is failing August 04, 2008 03:58AM |
). I mean objects that can be used in profitable endeavours. In business. In the economy that you'd like to connect it to.
Re: Why RepRap is failing August 04, 2008 04:04AM |
Re: Why RepRap is failing August 04, 2008 04:28AM |
Re: Why RepRap is failing August 04, 2008 07:52AM |
Re: Why RepRap is failing August 04, 2008 09:37AM |
Admin Registered: 19 years ago Posts: 1,487 |
Re: Why RepRap is failing August 04, 2008 09:57AM |
Admin Registered: 19 years ago Posts: 1,915 |
Re: Why RepRap is failing August 04, 2008 05:27PM |
Hm. Ru, I found your post quite entertaining. It was a bit defensive though, and some of your response points were flawed (probably due to the emotions that controlled the reactions)
Re: Why RepRap is failing August 04, 2008 07:23PM |
Re: Why RepRap is failing August 04, 2008 08:23PM |
Re: Why RepRap is failing August 04, 2008 08:31PM |
Re: Why RepRap is failing August 04, 2008 09:36PM |
Re: Why RepRap is failing August 04, 2008 09:48PM |
Re: Why RepRap is failing August 04, 2008 10:57PM |
Re: Why RepRap is failing August 04, 2008 11:33PM |
Re: Why RepRap is failing August 05, 2008 05:22AM |
...and that's why all schools today use Linux? A school isn't looking for cutting-edge mass installations, they're looking for a company (like Microsoft) that will take their money and give them a product that simply works. Works reliably, in a way that Windows does, and Linux does not
I'm not asking the dev team to get it together for my sake, it is for the sake of the other 99% of the world that doesn't have the luxury of enough free time to follow a dozen build blogs and fifty forum posts a day, just in order to build a printer that should be simple.
Let I checked, no one had even attempted to replicate Nophead's key innovations, so how could you know that it's impossible to do with more ordinary hardware?
It's a sort of "If you don't like it here, live somewhere else" attitude, and it's unfortunate.
I think you're right that we need a stable, well documented release
Re: Why RepRap is failing August 05, 2008 06:30AM |
Admin Registered: 19 years ago Posts: 7,883 |
Re: Why RepRap is failing August 05, 2008 09:47AM |
Re: Why RepRap is failing August 05, 2008 10:40AM |
Re: Why RepRap is failing August 05, 2008 01:10PM |
However, those are a lot of "if"s.|
Re: Why RepRap is failing August 05, 2008 04:11PM |
Re: Why RepRap is failing August 05, 2008 04:17PM |
Re: Why RepRap is failing August 05, 2008 05:01PM |
Re: Why RepRap is failing August 05, 2008 06:14PM |
Re: Why RepRap is failing August 05, 2008 06:40PM |
Re: Why RepRap is failing August 05, 2008 07:03PM |
Re: Why RepRap is failing August 05, 2008 07:51PM |
Re: Why RepRap is failing August 05, 2008 08:07PM |
Re: Why RepRap is failing August 05, 2008 08:18PM |
