Flexible build plate suggestions July 11, 2017 08:16AM |
Re: Flexible build plate suggestions July 11, 2017 08:25AM |
Re: Flexible build plate suggestions July 11, 2017 08:28AM |
Re: Flexible build plate suggestions July 11, 2017 09:33AM |
Re: Flexible build plate suggestions July 11, 2017 09:53AM |
leadinglights
Both will take about 100C
- Overhead transparency film
- Laminating pouches as they already have hot melt adhesive on one side (inside)
Mike
Re: Flexible build plate suggestions July 11, 2017 10:00AM |
Re: Flexible build plate suggestions July 11, 2017 11:08AM |
Re: Flexible build plate suggestions July 11, 2017 01:37PM |
Re: Flexible build plate suggestions July 11, 2017 01:43PM |
Re: Flexible build plate suggestions July 12, 2017 05:19PM |
Re: Flexible build plate suggestions July 12, 2017 05:31PM |
Re: Flexible build plate suggestions July 12, 2017 05:51PM |
Re: Flexible build plate suggestions July 13, 2017 04:55AM |
Re: Flexible build plate suggestions July 13, 2017 07:02PM |
Re: Flexible build plate suggestions July 14, 2017 03:47AM |
Re: Flexible build plate suggestions May 22, 2018 03:10AM |
Re: Flexible build plate suggestions May 22, 2018 03:18AM |
Re: Flexible build plate suggestions May 22, 2018 03:22AM |
Re: Flexible build plate suggestions May 22, 2018 04:29AM |
Re: Flexible build plate suggestions May 22, 2018 08:07AM |
Re: Flexible build plate suggestions May 22, 2018 09:53AM |
Re: Flexible build plate suggestions May 22, 2018 12:19PM |
Re: Flexible build plate suggestions May 22, 2018 03:44PM |
Re: Flexible build plate suggestions May 29, 2018 05:05PM |
JoeK1973
Hope you don't mind but I thought this thread was a good place to post what I'm thinking of doing - a magnetic flexible build plate (These prices are based on a 215mm x 225mm sheet for a 214x214 MK2 heater bed)
- I've bought a custom-shaped laser-cut 0.5mm 304 grade stainless steel sheet from LaserMaster (a smidge under £10). Send them a drawing of the shape you need by email (or I think you can attach it to the order form) and select 1mm but then specify 0.5mm in the comments.
- I'll be buying some Neodymium adhesive magnetic sheet (£15)
- And a sheet of PEI (but you could use whatever build surface you prefer I imagine) - about £8 in the UK.
The 0.5mm sheet should hopefully be flexible enough for bending/twisting to get the parts to release. I'll be careful not to over-flex the sheet. The Neodymium (higher Curie temperature) adhesive should be tolerant to normal (for PLA and PETG) heater bed temperatures.
I'll just cut the magnetic adhesive sheet into strips to cover the build plate - a bit like Angus did in his YouTube video. Then the PEI goes on the steel sheet. Spring steel would be nice but is hugely expensive. I'll post here again with results when I get it all installed.
Re: Flexible build plate suggestions May 30, 2018 02:40AM |
andornot
I cannot see how this is going to work as 304 stainless steel is not magnetic. I have a system also available but initially i will launch it for 220mmx220mm beds, to fit my duplicator i3. Beware of what neodymium sheet you use as the material is only good for 70 to 80 degrees, the material can be sourced for 130 degrees plus.
Re: Flexible build plate suggestions May 30, 2018 04:59PM |
JoeK1973
andornot
Haha, yes you're right. I realised this too late unfortunately. The stainless steel is 'slightly' magnetic but not really to the strength we need for a constantly moving Y-axis on i3 style machines. Pity as the laser cut shape (pic attached) is great. LaserMaster also do mild steel (magnetic) but the thinnest sheets they do in that material are 0.9mm which is probably not felxible enough for this purpose.
I'll keep a lookout for high temp neo magents, thanks - although I now think a better solution may be to place the magnets on the underside of the heated bed (and use a different steel for the buildplate lol) - the worry I have with that is that they may affect my sensor?
Re: Flexible build plate suggestions May 30, 2018 05:18PM |
andornot
I will launching a system for the duplicator 3i would this fit your machine? The bed size will be 220mm x 220mm with 15mm chamfered corners plus 10mm overhang for a lifting tab. The kit will be under £40.
Re: Flexible build plate suggestions May 31, 2018 12:25PM |
Re: Flexible build plate suggestions June 06, 2018 10:50AM |
Re: Flexible build plate suggestions June 06, 2018 08:49PM |
