need help making a hotbed controller work July 30, 2018 02:57PM |
Re: need help making a hotbed controller work July 31, 2018 12:23AM |
Re: need help making a hotbed controller work July 31, 2018 12:43AM |
Re: need help making a hotbed controller work July 31, 2018 12:46AM |
Re: need help making a hotbed controller work July 31, 2018 01:06AM |
Admin Registered: 13 years ago Posts: 7,001 |
Re: need help making a hotbed controller work July 31, 2018 03:26AM |
Dust
It plugs into your current bed output (ie 12v)
Re: need help making a hotbed controller work July 31, 2018 03:36AM |
No I would re-wire which is what I am doing as your analogy doesn't quite match up to my issue.Quote
the_digital_dentist
Here's something for you to meditate on: If the lights in your room are too dim, will changing the switch make them brighter?
Re: need help making a hotbed controller work July 31, 2018 05:31AM |
Re: need help making a hotbed controller work July 31, 2018 06:19AM |
Re: need help making a hotbed controller work July 31, 2018 07:48AM |
Re: need help making a hotbed controller work July 31, 2018 11:03AM |
Re: need help making a hotbed controller work July 31, 2018 11:06AM |
the_digital_dentist
Controllers and outboard switches are nice, but they don't make the bed get any hotter (just like changing the switches won't make that dimly lit room any brighter).
Re: need help making a hotbed controller work July 31, 2018 11:12PM |
Re: need help making a hotbed controller work August 01, 2018 03:51AM |
Dust
Also if your using a separate power supply, and it has a variable output, crank the voltage up.
Most cheap power supplies have a little variable resistor near the screw terminals. I tend to set these to 13.5v It makes a huge difference
Re: need help making a hotbed controller work August 01, 2018 06:44AM |
