Hello, Two of my constant headaches with my reprap i3 are the y-belt and the heatbed. I fixed it, it works fine for a while, then the same problem re-surfaced after a few days of printing.
#1 is the bed heat plate. the plate doesn't seem to be completely flat. which makes adjusting the gap between the nozzle very difficult.
#2 is the Y belt skep after server print.
I stumbled on an item on eBay, has anyone used it? what do you think of it? Does it buckle when the plate is heated? It looks like it has better support to the heat plate on my. Mine is a 3-point acrylic support, when the plate heated, it buckles, messes up the gap.
www.ebay.com]
Edited 1 time(s). Last edit at 08/31/2018 07:20AM by rich1812.
