Z axis homing problem
Posted by Baalaji V
September 20, 2018 08:51AM
Hi. I have done a Prusa model DIY 3d printer. I have a problem in Z axis Homing. I use Pronterface to control the movements of XYZ axis motor. when manual feeding is done, three stepper motors runs perfectly. But when homing is done XY motors runs perfectly but Z axis motors gets vibrated and then stops.
I have attached a video clip of it. In this first I moved all the axis for some distance and gave homing command using pronterface. During homing Z axis vibrates.
Video clip.
Please give me some suggestions.
Thanks in advance
with regards
Baalaji
Re: Z axis homing problem
September 20, 2018 09:18AM
I would say that the Z axis stepper current is low and needs to be adjusted.
Included is a video link
September 20, 2018 12:06PM
Z max feed rate is to high
in configuration.h find
#define DEFAULT_MAX_FEEDRATE { 300, 300, 5, 25 }
change to
#define DEFAULT_MAX_FEEDRATE { 300, 300, 2, 25 }
September 20, 2018 01:16PM
Okay thanks will check it.
with regards
Baalaji
September 21, 2018 06:43AM
In my Ramps LED 2 gets Lighted up continuously when connected with PSU. I replaced a new ramps and checked but no change.
And the hotend doesn't gets heated up when controlling using pronterface. But when I ran Ramps test code the Hotend got heated.
Thanks and regards
Baalaji
Edited 1 time(s). Last edit at 09/21/2018 06:50AM by Baalaji V.
September 21, 2018 09:38PM
What have you set the motherboard to in your firmware?
September 22, 2018 01:10AM
Z axis homing worked fine. Thanks sir.
The motherboard configuration is
#ifndef MOTHERBOARD
#define MOTHERBOARD BOARD_RAMPS_14_EFB
#endif
thanks and with regards
Baalaji
Edited 2 time(s). Last edit at 09/22/2018 01:15AM by Baalaji V.
September 22, 2018 02:25AM
Well motherboard is set fine, so firmware is using correct IO pins. (as long as you haven't edited the pins_ramps.h file)
the second possibility is dead mosfets on the ramps, but you say you replaced the ramps.
final possibility is that the mega has a fault. Dead IO pins. Sadly you have to replace the mega2560
I suggest you reinstall the ramps test firmware [reprap.org]
Check the 3 mosfet leds are turning on and off. If they dont, then definitely replace the mega
Edited 2 time(s). Last edit at 09/22/2018 02:29AM by Dust.
September 22, 2018 03:05AM
I reinstalled Ramps test code. It all worked fine. All the 4 leds blinked continuously(flickering) and all the motors worked perfectly.
And I uploaded new marlin 1.1.7 and still the same problem. Previously tried with I installed marlin 1.1.8, 1.1.9.
I checked voltage across hotbed connection while running ramps test code, it is about 11.4V. And when I checked after uploading Marlin in the same setup, it was about 0.04V.
And there is a very minute LED 3 blink.
Please give me a solution for this.
Thanks and regards
Baalaji
Edited 2 time(s). Last edit at 09/22/2018 03:29AM by Baalaji V.
September 22, 2018 03:33AM
That would indicate that its a firmware issue.
what version of arduino are you using?
1.8.6 is known to be buggy, please use 1.8.5 from [www.arduino.cc]
also please upload your configuration.h so I can check for other issues.
September 22, 2018 05:14AM
I have checked by using arduino 1.8.5 but the issue remained same. And I also tried with uploading using arduino 1.8.7 but no change.
I have attached my configuration.h file below.
[www.dropbox.com]
Thanks and regards
Baalaji
Edited 1 time(s). Last edit at 09/22/2018 05:51AM by Baalaji V.
September 22, 2018 09:30AM
Thanks for your suggestion @Dust. I solved the problem. The problem is in non working thermistor. I made it work.
Thanks and regards
Baalaji
