How to Connect Auto Leveling Sensor November 27, 2018 03:57AM |
Re: How to Connect Auto Leveling Sensor November 27, 2018 04:34AM |
Admin Registered: 13 years ago Posts: 7,000 |
Re: How to Connect Auto Leveling Sensor November 27, 2018 08:43AM |
X_PROBE_OFFSET_FROM_EXTRUDER 10 // X offset: -left +right [of the nozzle] Y_PROBE_OFFSET_FROM_EXTRUDER 63 // Y offset: -front +behind [the nozzle] Z_PROBE_OFFSET_FROM_EXTRUDER -0.5 // Z offset: -below +above [the nozzle]
X_PROBE_OFFSET_FROM_EXTRUDER 0 // X offset: -left +right [of the nozzle] Y_PROBE_OFFSET_FROM_EXTRUDER 25 // Y offset: -front +behind [the nozzle] Z_PROBE_OFFSET_FROM_EXTRUDER -0.5 // Z offset: -below +above [the nozzle]
Re: How to Connect Auto Leveling Sensor November 29, 2018 03:16AM |
Dust
The page you linked to has multiple screen shots on how to set it up, highlighted even... what more do you need?
There is even a text file with all the changes you need....
It just plugs into the 3 pin Z endstop plug.
"I plugged my SN04-N into the 5v supply line works fine.
Brown wire to 5V
Black wire to NO contact
Blue wire to Ground"
But "similar" concerns me... there are PNP and NPN types and 12v and 6v versions and 4 and 8 mm measuring distance versions...
