Thermal Runaway, system stopped! Heater_ID: bed September 27, 2018 01:56AM |
Re: Thermal Runaway, system stopped! Heater_ID: bed September 27, 2018 10:43AM |
foul_owl
Getting the error:
Which causes octoprint to panic and disconnect my printer.
This happens maybe 10 minutes after starting a print, after everything is warmed up and the actual printing starts.
Happens almost every time.
However, when I reset the ramps board and reconnect, I can leave the printer idling at full bed temp (90C) for hours and hours with no issues.
This problem also didn't start until I updated my firmware (I wanted better bed autoleveling, as the older version of marlin I was using didn't have all the new algorithms)
So....I'm guessing this is a firmware issue. Trouble is, not sure what settings to tweak to fix this.
Is there a way to disable thermal runaway protection? Or what else could I try?
Re: Thermal Runaway, system stopped! Heater_ID: bed September 27, 2018 12:59PM |
Re: Thermal Runaway, system stopped! Heater_ID: bed September 27, 2018 01:30PM |
Re: Thermal Runaway, system stopped! Heater_ID: bed September 27, 2018 02:01PM |
Re: Thermal Runaway, system stopped! Heater_ID: bed September 27, 2018 04:28PM |
Re: Thermal Runaway, system stopped! Heater_ID: bed September 27, 2018 04:48PM |
Re: Thermal Runaway, system stopped! Heater_ID: bed September 28, 2018 03:53AM |
thats a false sense of security buddy,,, what will happen is the bed mosfet will ramp up the power to maintain/achieve the required heat... then you have your melt down.Quote
foul_owl
There seems to be no fire hazard as the bed can only reach 90C max anyway, if the thermistor falls off it's not going above 90.
Re: Thermal Runaway, system stopped! Heater_ID: bed September 29, 2018 02:40PM |
jinx
Re: Thermal Runaway, system stopped! Heater_ID: bed January 26, 2019 02:03AM |
Re: Thermal Runaway, system stopped! Heater_ID: bed January 26, 2019 02:26AM |
Admin Registered: 13 years ago Posts: 7,000 |
Re: Thermal Runaway, system stopped! Heater_ID: bed January 26, 2019 03:51PM |
LFG
I am running 3 different printers that are home built I3 clones running Ramps 1.4s with Marin 1.1.7 firmware. I am having thermal runaway errors at exactly the same spot across different printers. I was using an older g-code slice with Cura 3.5 that I've printed 12 to 20 times but the last 7 tries have failed. I have re-sliced the g-code with Cura 3.6 a few times and although it has worked it only works 20% of the time. In fact after re-slicing and rotating the position it still fails in the same location.
Re: Thermal Runaway, system stopped! Heater_ID: bed January 27, 2019 01:37AM |
Re: Thermal Runaway, system stopped! Heater_ID: bed January 27, 2019 04:54PM |
Re: Thermal Runaway, system stopped! Heater_ID: bed February 02, 2019 12:48PM |
