Don't buy belts from FYSETC on Aliexpress.
Posted by Dust
May 30, 2019 07:45PM
I was looking for belts for a new printer and specifically wanted PU with steel core.
FYSETC advertised such a belt, clearly listening the material as "PU with steel core"
It arrived and didn't feel right, I examined the end of the belts and there is no glint of metal.
I tested with magnets (which stick to other belts of this type fine) and there was no magnetic attraction,
The sale went into dispute.
Sadly Aliexpress deputes process is a picture.. and it looks like a belt!!
So be warned... Don't expect any steel core in your belts from FYSETC
Re: Don't buy belts from FYSETC on Aliexpress.
May 31, 2019 03:36PM
Good to know they don't sell as advertised but I will say that you don't actually want steel core belts with the normal pulleys used for 3d printers. If I remember correctly, you really don't wanna use a pulley with less than 40 teeth for a steel core belt. Most 3d printers either use 20 or 16 tooth belts. So be mindful of that. The smaller diameter causes the steel to snap after a short time do to excessive bending of the metal.
May 31, 2019 07:56PM
Prusa mk2/mk3 uses them with no issues and since im building a mk3 clone...
June 02, 2019 12:35AM
After getting access to a microscope and taking clear photos that show the core is some sort of fibrous material and looks nothing like core of a real steel core belt. Aliexpress has come to the rescue and accepted that the product is not as described.
Sadly I will never get the 3+ hours I've had to waste on this crap back or compensated for.. but its still a win...
June 03, 2019 03:31AM
Dust
No, they dont? From where did you get this?
June 03, 2019 03:54AM
From my genuine mk2 belts! straight from Prusa!
It is very obvious from the ends, and you can hang magnets from the belts
Edited 2 time(s). Last edit at 06/03/2019 04:01AM by Dust.
June 03, 2019 11:17AM
Okay. Was fairly certain they used regular fiberglass belts. But guess it is true what you say!
