Generating Gcode for a pen plotter on a Mac...? (issues) June 13, 2019 04:48PM |
Admin Registered: 11 years ago Posts: 3,096 |
Traceback (most recent call last): File "gcodetools.py", line 6753, in gcodetools.affect() File "/Applications/Inkscape 0.91 .app/Contents/Resources/share/inkscape/extensions/inkex.py", line 268, in affect self.effect() File "gcodetools.py", line 6677, in effect self.path_to_gcode() File "gcodetools.py", line 4590, in path_to_gcode [ self.parse_curve([subpath], layer) for subpath in csp ] File "gcodetools.py", line 3734, in parse_curve c += biarc(sp1,sp2,0,0) if w==None else biarc(sp1,sp2,-f(w[k][i-1]),-f(w[k])) File "gcodetools.py", line 2305, in biarc r = TS.mag()/v.mag()*2 ZeroDivisionError: float division by zero
Re: Generating Gcode for a pen plotter on a Mac...? (issues) June 13, 2019 06:10PM |
Re: Generating Gcode for a pen plotter on a Mac...? (issues) June 14, 2019 02:52AM |
etfrench
There are errors in lotus.svg at the two inner sharp points on the right hand side. You may be able to correct them by mirroring the left side.
Re: Generating Gcode for a pen plotter on a Mac...? (issues) June 14, 2019 07:30AM |
Re: Generating Gcode for a pen plotter on a Mac...? (issues) June 14, 2019 05:40PM |
Re: Generating Gcode for a pen plotter on a Mac...? (issues) June 15, 2019 03:24AM |
etfrench
Actually, there are quite a few other errors in the .svg. Most of the tips are malformed. I'd recommend not doing this in Inkscape. Fusion 360 is still able to generate gcode for all of the valid geometry. [knowledge.autodesk.com]
Re: Generating Gcode for a pen plotter on a Mac...? (issues) June 17, 2019 01:12AM |
Re: Generating Gcode for a pen plotter on a Mac...? (issues) June 17, 2019 04:30AM |
diegomonzon
if you use illustrator try Adobe Illustrator to G-code panel V2.0
[diegomonzon.com]
thanks
Diego
1|40|80|~/Documents/Plotterfiles|eerste_mandala_2|||||||||M400 M280 P0 S25 M400|M400 M280 P0 S40 M400|||
