Anet A8 Axis Issues & Home Position July 17, 2019 12:58AM |
Re: Anet A8 Axis Issues & Home Position July 17, 2019 01:11AM |
Admin Registered: 13 years ago Posts: 6,995 |
Re: Anet A8 Axis Issues & Home Position July 17, 2019 05:19AM |
Re: Anet A8 Axis Issues & Home Position July 17, 2019 10:12AM |
Re: Anet A8 Axis Issues & Home Position July 17, 2019 11:31AM |
Re: Anet A8 Axis Issues & Home Position July 17, 2019 01:17PM |
Re: Anet A8 Axis Issues & Home Position July 17, 2019 03:45PM |
3D Printer Dude
I have an Anet A8 and just flashed my system with Marlin 1.1.9
I booted up system and tried getting used to the difference in the LCD, which mine is the 2004. Upon moving each axis, I found that in one direction I could take it to the limit, but the other way, it would only go so far.
Z Axis: would go up as far as I wanted, but down, would only go down about 4" above hotbed and stop. Not even getting close to limit switch
X Axis: Facing the printer, would go all the way to the right, but just shy of the limit switch to the left by about 1/2"
Y Axis: would come all the way forward, but about 3 1/2" short of hitting limit switch in rear
Why is this, and how do I fix it New to Marlin, so not sure what I am going to also have to do, to get everything back to working. According to the lcd, it shows a ? where the sd card is on the screen , and weird 0 & ? for the axis #'s
Also is there any documentation or videos on what the screen operations are on the 2004 lcd that comes stock on the A8's. Very confusing compared to the original way.
Re: Anet A8 Axis Issues & Home Position July 17, 2019 03:47PM |
Re: Anet A8 Axis Issues & Home Position July 17, 2019 09:17PM |
Re: Anet A8 Axis Issues & Home Position July 18, 2019 12:44AM |
Re: Anet A8 Axis Issues & Home Position July 18, 2019 11:50AM |
3D Printer Dude
I actually found documentation at the Marlin site, but not specific to the Anet A8. Also, can someone tell me when I am compiling, I get two errors that show while compiling, but finishes compiling with a done compiling finish. The upload also goes through with no problems. The following is the two strings of text I get. While compiling they show as yellow or amber text, not red.
Error while detecting libraries included by C:\users\bel\AppData\local\Temp\Arduino_build_798526\sketch\temperature\ccp
Error while detecting libraries included by C:\users\bel\AppData\local\Temp\Arduino_build_798526\sketch\Sd2Card\ccp
I have searched for the string or path on computer that has Arduino/Marlin, and computer tells me it doesn't exsist.
Is there a way to print out my compilation to the printer (paper printer)
