"Is there any body know how to get a consistent print speed that can be always meet my setting value?"
this is a loaded question. i'm going to assume you are talking about printer settings as it relates to acceleration.
is there a specific reason you want circles and non lines to be at 100mm/s ?
this seems to violate the tool path acceleration rules in firmware.
you can increase firmware acceleration in firmware settings,
in most firmware settings are in the lcd menu with acceleration settings.
some have limits to protect the machine. to much inertia can damage the nozzle, the frame or the belts. its the sudden change in directional velocity that causes these issues.
if your code is set to default to arc segments then it should be changed to use line segments if the arc is the issue, but this seems unlikely unless there are a lot of arc's
can you list our gcode so someone can verify it is line segment generated.
updated comments
if it is generated by cura then the code is line generated not arc,
you might be able to increase acceleration around curves by lowering resolution detail
making curved lines a little longer so ramping of speed can happen a little bit
look for a setting called Maximun resolution change this from 0.01 or whatever it is set to and change it to 0.1 this will make line segment longer and allow more of an acceleration, however the segments are still quite short for full speed to be reached.
Edited 4 time(s). Last edit at 10/13/2019 03:07PM by jamesdanielv.
