Tenlog TL-D3 Pro Temperature settings
Posted by kmikesch
November 16, 2019 07:27AM
Hi all.
How can i change the waiting temperature of the Nozzle?
Whenever i want to print something with this printer which uses both extruders in the same model it takes more than an h longer. When one nozzle is finished printing within the layer it goes to the resting position an resets the temperature to 200°C but i want to print with 235°C (or any different temperature) so each time it needs to reheat the nozzle which takes forever in this printer. It isnt a slicer (cura) thing i changed all temperatures to my desired value but it still goes to 200 sometimes even 190°C its making me crazy.
I think i need to change the firmware - Id like to change some settings there anyway (like the preheat temperatures and if its easy enough the layout of the menu)
What can i do?
How is it possible that it just holds the temp on the extruders?
How can i change the firmware?
Thank you very much
Re: Tenlog TL-D3 Pro Temperature settings
November 16, 2019 07:54AM
"How is it possible that it just holds the temp on the extruders?"
That is a bad idea, if you don't lower the temperature on the unused hotend it will ooze and make a mess.
November 16, 2019 08:10AM
It is a cura setting
material_standby_temperature = 190
