LulzBot TK0
Posted by jebba
Re: LulzBot TK0
June 22, 2013 10:36AM
Yes, I only had a few of those drop-in type of nuts. They are nice but ridiculously expensive. I only use them for post-construction attachments like LCD/keypad/spool holder/etc.
Re: LulzBot TK0
June 22, 2013 10:39AM
Mechanical In stock Extrusion 500mm (black) 4 ea $4.15 $16.60 $16.00 NFSB5-2020-500 4 See Misumi Quote
Mechanical In stock Extrusion 500mm (black), tapped on one ends 4 ea $5.84 $23.36 $23.20 NFSB5-2020-500-LTP 4 See Misumi Quote
Mechanical In stock Extrusion 500mm (black), tapped on both ends 2 ea $7.42 $14.84 $15.20 NFSB5-2020-500-TPW 4 See Misumi Quote
[www.matter-replicator.com]
Re: LulzBot TK0
June 22, 2013 10:45AM
Do I need stoppers for the nuts?
Edited 1 time(s). Last edit at 06/22/2013 10:46AM by rsilvers.
Re: LulzBot TK0
June 22, 2013 10:46AM
Re: LulzBot TK0
June 22, 2013 10:51AM
HNKK5-5
$19.32 for an unknown sized pack of sheet-metal ones - probably 100.
Re: LulzBot TK0
June 22, 2013 10:58AM
Yes, that would be a 100 pcs. bag according to the price, though my quotes are in euros.
No. Assembly works just like a MendelMax for example, any t-nut that fits the profile and a screw to lock the printed part against it.
Edited 1 time(s). Last edit at 06/22/2013 11:00AM by MPower.
Re: LulzBot TK0
June 22, 2013 11:01AM
I have just about everything ordered. ~$637 so far. There are just a few things I did not include in the cost - like the wire. Also I will get the power supply and power cable from an old PC. I am going to say that one can do it for under $700.
RobTheSlob changed my life when he showed me [www.boltdepot.com] - saved ~$80 over McMaster.
Edited 4 time(s). Last edit at 06/22/2013 07:17PM by rsilvers.
open | download - TAZ-BOM-rs.ods (24.2 KB)
Re: LulzBot TK0
June 22, 2013 11:19AM
One does have to wonder though - you can build this for $800 or I could have just ordered a 12x16x10" RigidBot for $855. They claim Oct delivery.
Re: LulzBot TK0
June 22, 2013 12:34PM
What do you-all think of standard bearings vs the $5.95 each plastic bushings they use? It is like $65 vs $15.
Anonymous User
Re: LulzBot TK0
June 22, 2013 03:42PM
ball bearings all the way. I have found them for $18 for 10.... unfortunately you need 11
Re: LulzBot TK0
June 22, 2013 03:46PM
[www.ebay.com]
Re: LulzBot TK0
June 22, 2013 03:58PM
You can get two more for cheap.
www.ebay.com/itm/170944517417?redirect=mobile
Re: LulzBot TK0
June 22, 2013 07:13PM
Bolt Depot Prices:
Your Order
Product# Description Quantity Unit Price Subtotal
13633 Metric socket cap, Class 12.9 steel black oil finish, 3mm x 0.5mm x 5mm 30 pcs $0.10 $3.00
13637 Metric socket cap, Class 12.9 steel black oil finish, 3mm x 0.5mm x 12mm 100 pcs $5.56/100 $5.56
13640 Metric socket cap, Class 12.9 steel black oil finish, 3mm x 0.5mm x 25mm 4 pcs $0.13 $0.52
6510 Metric socket cap, Class 12.9 steel black oil finish, 4mm x 0.7mm x 20mm 4 pcs $0.13 $0.52
15435 Metric socket cap, Class 12.9 steel black oil finish, 4mm x 0.7mm x 60mm 3 pcs $0.21 $0.63
6519 Metric socket cap, Class 12.9 steel black oil finish, 5mm x 0.8mm x 10mm 100 pcs $5.63/100 $5.63
6521 Metric socket cap, Class 12.9 steel black oil finish, 5mm x 0.8mm x 14mm 8 pcs $0.10 $0.80
6564 Metric socket cap, Class 12.9 steel black oil finish, 8mm x 1.25mm x 35mm 2 pcs $0.27 $0.54
8827 Metric set screws, Allen, Cup point, Class 14.9 steel black oil finish, 3mm x 0.5mm x 5mm 12 pcs $0.09 $1.08
4806 Metric hex lock nuts nylon insert, Zinc plated class 8.8 steel, 8mm x 1.25mm 5 pcs $0.11 $0.55
4524 Metric flat washers, Zinc plated steel, 3mm 100 pcs $1.16/100 $1.16
4525 Metric flat washers, Zinc plated steel, 4mm 15 pcs $0.05 $0.75
4526 Metric flat washers, Zinc plated steel, 5mm 100 pcs $1.40/100 $1.40
4529 Metric flat washers, Zinc plated steel, 8mm 15 pcs $0.05 $0.75
4783 Metric hex nuts, Zinc plated class 8.8 steel, 3mm x 0.5mm 4 pcs $0.05 $0.20
4784 Metric hex nuts, Zinc plated class 8.8 steel, 4mm x 0.7mm 6 pcs $0.05 $0.30
4788 Metric hex nuts, Zinc plated class 8.8 steel, 8mm x 1.25mm 5 pcs $0.06 $0.30
6041 Metric tap bolts, Zinc plated class 8.8 steel, 4mm x 0.7mm x 20mm 6 pcs $0.12 $0.72
13339 Metric socket button head, Class 12.9 steel black oil finish, 4mm x 0.7mm x 8mm 6 pcs $0.09 $0.54
6896 Metric wing nuts, Stainless steel 18-8, 4mm x 0.7mm 6 pcs $0.39 $2.34
6899 Metric wing nuts, Stainless steel 18-8, 8mm x 1.25mm 1 piece $0.67 $0.67
Summary
Subtotal: $27.96
Tax: $1.75
Shipping: $6.83
Total: $36.54
I saved about $80 over McMaster hardware!
Edited 1 time(s). Last edit at 06/22/2013 07:18PM by rsilvers.
Re: LulzBot TK0
June 24, 2013 05:06PM
I am not sure if they switched to Igus bushings in the public STLs also, so you might wanna check before ordering the LM10UU. Even so, the STLs for LM10UU had the hole slichtly larger then the regular LM10UU: R9.7mm vs R9.5mm, never bothered to ask why exactly.
Re: LulzBot TK0
June 25, 2013 07:01AM
Re: LulzBot TK0
June 26, 2013 11:26AM
The only 3D printer kickstarter I'm aware of that has delivered all the kickstarter-ordered printers is Printrbot. I wouldn't hold your breath, especially if they aren't sharing their design/code/BOM/etc.
Re: LulzBot TK0
June 27, 2013 10:27AM
erlau Wrote:
> I am planning to use a PN: 6112K47 from McMaster
> for my build. They are hardened ground steal (not
> stainless) 10mm X 500 for about $15 instead of
> $35.
That is also what I bought, but I just discovered that you can buy Misumi SFU10-500 for ~$16.50 each. They are H7 ground and not stainless. Comes to about $13 more than the McMaster. I have no evidence they are better though.
Re: LulzBot TK0
June 27, 2013 10:32AM
> delivery.
I would not either. I think they will discover that when you make a bed that size, it is very expensive to make it flat across the entire surface! My pool table may be that flat, but it is heavy and expensive. A cast Mic-6 plate would be nice - it is what I bought for my TAZ build - but it is not in their budget. Also for 16 inches of travel, I would not even want to use 10mm rods. When you go larger size, then the cost goes up and the shipping weight goes up. They will have to either compromise, and use smaller rods than ideal, or eat into profits. And who knows when they will ship.
