Hobbed Bolt October 02, 2012 09:08AM |
Re: Hobbed Bolt October 02, 2012 09:27AM |
Re: Hobbed Bolt October 02, 2012 09:32AM |
Re: Hobbed Bolt October 02, 2012 11:35AM |
Re: Hobbed Bolt October 02, 2012 02:54PM |
Re: Hobbed Bolt October 02, 2012 02:58PM |
Re: Hobbed Bolt October 02, 2012 03:59PM |
Re: Hobbed Bolt October 02, 2012 04:08PM |
Re: Hobbed Bolt October 03, 2012 03:23AM |
Re: Hobbed Bolt October 03, 2012 10:57AM |
Re: Hobbed Bolt October 03, 2012 06:54PM |
Re: Hobbed Bolt October 03, 2012 07:55PM |
Re: Hobbed Bolt October 03, 2012 10:06PM |
Re: Hobbed Bolt October 04, 2012 07:00PM |
Re: Hobbed Bolt October 19, 2012 04:03AM |
Admin Registered: 17 years ago Posts: 7,879 |
How frequently does everyone clean their Hobbed-bolt to avoid clogging while using PLA?
Is it possible to have an extruder design that auto-cleans the Hobbed-bolt?
Re: Hobbed Bolt October 19, 2012 05:36AM |
nophead
In normal use I don't clean my hobbed bolts. They produce a small amount of dust, that's all. If I have a jam for some reason then it will strip the filament and fill the teeth. In which case I remove it and clean it with a wire brush, but when everything is working properly the teeth stay clean. They may have some loose dust on them, but that is not the same as being clogged with torn off plastic.
Re: Hobbed Bolt October 20, 2012 01:33AM |
