gCreate gMax 2 extruder motor not working.
Posted by Tempest815
May 01, 2020 03:57PM
Hi all,
I have a gCreate gMax 2 (https://www.gcreate.com/gmax-2) and it's essentially a big RepRap machine: Uses Marlin 1.1.9, uses RAMPs and an Arduino, etc.
I just recovered from a blown trace on the back board (power management and routing?). At first I was getting M600 errors, but those have apparently disappeared. Motion is fine, lights work, all commands check out okay but the extruder won't move when I try printing or when I try to purge filament. I can push filament through the hot end manually, that works. I tried replacing the ribbon cables it uses from the extruder board and that did nothing, so that's not the issue there. Everything is hooked up correctly on the back board I believe, I moved each wire from the bad board to the new one, matching it as I went. Motor isn't warm to the touch, there's no evidence of short circuiting that I can see.
I also ran an M503 command to see what's going on in the values and got this:
M503
echo: G21 ; (mm)
echo: M149 C ; Units in Celsius
echo:Filament settings: Disabled
echo: M200 D1.75
echo: M200 D0
echoconfused smileyteps per unit:
echo: M92 X80.00 Y80.00 Z800.00 E93.86
echo:Maximum feedrates (units/s):
echo: M203 X600.00 Y600.00 Z15.00 E25.00
echo:Maximum Acceleration (units/s2):
echo: M201 X500 Y500 Z350 E5700
echo:Acceleration (units/s2): P R T
echo: M204 P4000.00 R9000.00 T4000.00
echo:Advanced: B S T X Y Z E
echo: M205 B20000 S0.00 T0.00 X6.00 Y6.00 Z0.30 E5.00
echo:Home offset:
echo: M206 X0.00 Y0.00 Z0.00
echo:Auto Bed Leveling:
echo: M420 S0
echo: G29 W I0 J0 Z-0.10792
echo: G29 W I1 J0 Z-0.02833
echo: G29 W I2 J0 Z-0.00417
echo: G29 W I3 J0 Z-0.00708
echo: G29 W I4 J0 Z-0.04542
echo: G29 W I5 J0 Z-0.05958
echo: G29 W I6 J0 Z-0.02833
echo: G29 W I7 J0 Z-0.05250
echo: G29 W I0 J1 Z-0.06542
echo: G29 W I1 J1 Z-0.00625
echo: G29 W I2 J1 Z0.05000
echo: G29 W I3 J1 Z0.06625
echo: G29 W I4 J1 Z-0.01792
echo: G29 W I5 J1 Z0.04042
echo: G29 W I6 J1 Z-0.01292
echo: G29 W I7 J1 Z-0.03292
echo: G29 W I0 J2 Z-0.08042
echo: G29 W I1 J2 Z0.06917
echo: G29 W I2 J2 Z0.06042
echo: G29 W I3 J2 Z0.06667
echo: G29 W I4 J2 Z-0.00042
echo: G29 W I5 J2 Z-0.05375
echo: G29 W I6 J2 Z-0.05417
echo: G29 W I7 J2 Z-0.05875
echo: G29 W I0 J3 Z-0.05583
echo: G29 W I1 J3 Z0.02542
echo: G29 W I2 J3 Z0.08792
echo: G29 W I3 J3 Z0.05958
echo: G29 W I4 J3 Z0.02750
echo: G29 W I5 J3 Z0.01333
echo: G29 W I6 J3 Z0.03792
echo: G29 W I7 J3 Z-0.04292
echo: G29 W I0 J4 Z-0.03333
echo: G29 W I1 J4 Z0.10958
echo: G29 W I2 J4 Z0.06458
echo: G29 W I3 J4 Z0.09125
echo: G29 W I4 J4 Z0.04333
echo: G29 W I5 J4 Z0.06333
echo: G29 W I6 J4 Z0.00125
echo: G29 W I7 J4 Z0.02500
echo: G29 W I0 J5 Z0.01458
echo: G29 W I1 J5 Z0.16667
echo: G29 W I2 J5 Z0.10833
echo: G29 W I3 J5 Z0.12875
echo: G29 W I4 J5 Z0.07833
echo: G29 W I5 J5 Z0.08208
echo: G29 W I6 J5 Z0.11333
echo: G29 W I7 J5 Z0.09417
echo: G29 W I0 J6 Z0.11792
echo: G29 W I1 J6 Z0.24500
echo: G29 W I2 J6 Z0.16917
echo: G29 W I3 J6 Z0.24375
echo: G29 W I4 J6 Z0.12208
echo: G29 W I5 J6 Z0.13333
echo: G29 W I6 J6 Z0.14417
echo: G29 W I7 J6 Z0.13792
echo: G29 W I0 J7 Z0.19667
echo: G29 W I1 J7 Z0.28708
echo: G29 W I2 J7 Z0.24333
echo: G29 W I3 J7 Z0.21250
echo: G29 W I4 J7 Z0.14583
echo: G29 W I5 J7 Z0.14333
echo: G29 W I6 J7 Z0.17125
echo: G29 W I7 J7 Z0.21083
echo:Material heatup parameters:
echo: M145 S0 H200 B70 F0
echo: M145 S1 H240 B110 F0
echotongue sticking out smileyID settings:
echo: M301 P22.41 I1.74 D72.07
echo:Z-Probe Offset (mm):
echo: M851 Z-2.00
echo:Linear Advance:
echo: M900 K0.10
echo:Filament load/unload lengths:
echo: M603 L0.00 U100.00
Any ideas? I think I've exhausted everything I can think of.
