Should be straight forward.
1.) Hook up the + from the RAMPS output (D8 +) to the + of the relay (Pin 3)
2.) Hook up the - from the RAMPS output (D8 -) to the - of the relay (Pin 4)
3.) Hook up one of the AC wires directly to one of the heating element terminals
4.) Hook up the other AC wire to an in-line fuse, then to the relay (Pin 1)
5.) Hook up the relays' Pin 2 to the other eating element terminal
Done.
It would be a good idea to have a bi-metal fixed temp thermostat attached as well to prevent a runaway condition. A thermal fuse is a good idea as well. Just wire either device in-line with the AC leads.
As far as the 12VDC source, simply shunt the positive RAMPS terminals (5A and 11A) together and hook up you positive 12VDC to either one. No need to do anything to the grounds, they already common at least according to the
schematic.
Don't worry about the current draw of the SSR, it's nearly nothing (15mA DC). [
www.crydom.com]
- akhlut
Just remember - Iterate, Iterate, Iterate!
myhomelessmind.blogspot.com]
