Thermistor Reading Negative Degrees
Posted by madebotix
February 15, 2021 04:30AM
Hi all.
I am running MK4DUO (a branch of marlin), on an Arduino Mega and Ramps 1.4.
I have an E3D V6 Lite hotend and am getting a thermistor reading of -49 degrees Celsisus at room temperature.
I have set the thermistor to the default Epcos 4.7k to no avail.
Which one should work?
I have attached my configuation file.
Thanks
open | download - Configuration_Temperature.h (24.6 KB)
Re: Thermistor Reading Negative Degrees
February 15, 2021 07:50AM
a negative reading like that is normally a unplugged thermistor
or firmware is looking at wrong port
or thermistor is plugged into wrong port
or broken wire leading to thermistor
February 15, 2021 08:36AM
Ah ha. Got it. Went through all the options in the firmware and found it was in wrong pin. Thanks!
