Hi all,
I have just build a printer with a Trianglelab Cyclops. I did not find much information about how to setup the tool changes. Finally, after some digging I found that by just adding the cyclops measurements on the "
Single extruder MM setup" on Prusa Slicer (see attached screenshot), I was able to slice and print my first piece. The slicer did all for me. Good.
However, I am interested in the "Change Tool" script, so I can do some more fancy things like a unassisted filament change (a few layers with color one, go to a corner, change filament, purge and resume).
I haven't been able to find any example of such script. I know it is not as simple as remove filament, add the new one because some movements must be done in order not to end up with a clogged hotend.
Does somebody have an example of script I could use?
open |
download -
(272.5 KB)
