Noisy power supply fan April 23, 2021 01:32AM |
Re: Noisy power supply fan April 23, 2021 02:31PM |
Re: Noisy power supply fan April 24, 2021 02:50AM |
Re: Noisy power supply fan April 26, 2021 07:54PM |
Re: Noisy power supply fan April 26, 2021 09:31PM |
Re: Noisy power supply fan April 26, 2021 11:11PM |
DragonFire
The most effective ways I've found to quieten a fan are;-
1) Paint all the surfaces to reduce drag. Be careful not to get any paint inside the fan.
2) Give it an overnight soak in WD40, drain, shake and dry thorouhly before plugging in.
Re: Noisy power supply fan April 27, 2021 05:22AM |
Re: Noisy power supply fan April 27, 2021 07:05AM |
Re: Noisy power supply fan April 27, 2021 07:15AM |
Re: Noisy power supply fan April 27, 2021 09:07AM |
Re: Noisy power supply fan April 29, 2021 12:51AM |
the_digital_dentist
DragonFire
1) What sort of magic paint is that? Which surfaces are you painting- the blade? the housing?
2) Did you know that WD40 isn't actually a lubricant, but it can be a pretty good degreaser (as in taking the lube out of bearings). It's hard to believe that would quiet a fan, unless it stopped turning completely.
If you really want to quiet a fan down, run it at low voltage (which will reduce speed) unless it uses mag-lev bearings (Sunon).
Re: Noisy power supply fan April 29, 2021 09:40AM |
DragonFire
2) WD40 is a contact switch cleaner. Brushless motor with preferably no dust. Think about it...
Re: Noisy power supply fan April 29, 2021 12:51PM |
Re: Noisy power supply fan April 29, 2021 01:58PM |
Re: Noisy power supply fan April 29, 2021 05:23PM |
Re: Noisy power supply fan April 29, 2021 05:56PM |
MKSA
the_digital_dentist
I'm out...
Just when it starts to be funny ?
Re: Noisy power supply fan April 29, 2021 11:56PM |
Re: Noisy power supply fan May 17, 2021 01:51PM |
DragonFire
Re: Noisy power supply fan May 24, 2021 09:33PM |
