Removing 3M 468MP adhesive March 21, 2016 10:26AM |
Re: Removing 3M 468MP adhesive March 21, 2016 10:55AM |
Re: Removing 3M 468MP adhesive March 21, 2016 04:46PM |
Re: Removing 3M 468MP adhesive March 22, 2016 10:08PM |
Re: Removing 3M 468MP adhesive March 22, 2016 10:39PM |
Re: Removing 3M 468MP adhesive December 25, 2016 11:24AM |
Re: Removing 3M 468MP adhesive December 25, 2016 12:54PM |
Re: Removing 3M 468MP adhesive October 25, 2017 04:03PM |
Roxy
You people are making things much more difficult than you need to.
3M 468MP (or 3M 200MP) adhesive is easily removed. You just take a blob of Peanut Butter (Creamy... Not Chunky!) and smear a thin layer across the surface to be cleaned. Try to get a 1/16" layer across the entire sheet. Then just wait over night and use a squidgy to remove the peanut butter. And then soap and water to remove the grease and oil from the peanut butter.
I just did a 400mm x 400mm silicon heater pad with only 10 minutes of actual work.
Re: Removing 3M 468MP adhesive October 25, 2017 04:31PM |
Re: Removing 3M 468MP adhesive October 25, 2017 05:48PM |
Re: Removing 3M 468MP adhesive October 26, 2017 03:31PM |
Re: Removing 3M 468MP adhesive October 30, 2017 03:07AM |
Re: Removing 3M 468MP adhesive February 25, 2020 04:10AM |
Roxy
Re: Removing 3M 468MP adhesive April 30, 2020 03:54PM |
Re: Removing 3M 468MP adhesive April 30, 2020 07:03PM |
WZ9V
I've tried Goo Gone Pro but it's just not dissolving the 3M 468MP adhesive.
Can someone recommend a solvent that will dissolve the adhesive. I'll trying to cleanup a glass plate for a new layer of PEI but having a devil of a time getting rid of the old adhesive.
Re: Removing 3M 468MP adhesive May 01, 2020 02:18AM |
AbuMaia
I think the peanut butter "tip" was a prank. I just peeled off a well-used PEI film from my magnetic print surface, and applied a layer of peanut butter to the remaining residue, and left it overnight in an old spool baggie. At least 17 hours later, I took it out and scraped off the peanut butter, to find all of the adhesive residue still on the metal sheet. It literally took none off, and barely reduced its residual stickiness.
Gonna have to let it soak in some acetone or alcohol instead I guess.
Re: Removing 3M 468MP adhesive April 24, 2021 04:24PM |
Re: Removing 3M 468MP adhesive April 24, 2021 10:57PM |
Re: Removing 3M 468MP adhesive April 25, 2021 03:53AM |
Re: Removing 3M 468MP adhesive April 25, 2021 06:40AM |
Re: Removing 3M 468MP adhesive April 25, 2021 06:33PM |
Re: Removing 3M 468MP adhesive April 25, 2021 10:38PM |
Re: Removing 3M 468MP adhesive April 27, 2021 12:50AM |
Re: Removing 3M 468MP adhesive April 27, 2021 07:12AM |
Re: Removing 3M 468MP adhesive July 24, 2021 03:12PM |
