extrusion problem November 22, 2021 12:53AM |
Re: extrusion problem November 22, 2021 03:53AM |
Admin Registered: 13 years ago Posts: 6,995 |
Re: extrusion problem November 22, 2021 08:43AM |
Re: extrusion problem November 22, 2021 01:46PM |
Re: extrusion problem November 22, 2021 08:39PM |
Is there a possibility of damaging a brass nozzle with this method?Quote
dekutree64
Clean the nozzle if you haven't already (or buy a new one). I just hold it in a fire with pliers until all the plastic burns into white powder and then wash under running water, using a needle to scrape around inside.
How exactly would you do that? Same method -- burn off the plastic into powder, then scrape/poke it out?Quote
dekutree64
Clean the heatbreak as well if it has any plastic in it.
Re: extrusion problem November 23, 2021 01:48AM |
Re: extrusion problem November 23, 2021 02:38AM |
Yeah, I've been recently using this for the same purpose:Quote
dekutree64
One thing that helps is to use a binder clip to hold a piece of cloth around the filament between the spool and extruder, so any dust gets wiped off before going into the bowden tube/nozzle.
Re: extrusion problem November 23, 2021 12:00PM |
Re: extrusion problem November 24, 2021 06:57PM |
