Z AXIS CRASHES INTO HEATBED WHEN PRINT START November 04, 2012 05:58PM |
Re: Z AXIS CRASHES INTO HEATBED WHEN PRINT START November 05, 2012 07:34AM |
Re: Z AXIS CRASHES INTO HEATBED WHEN PRINT START November 05, 2012 03:57PM |
Re: Z AXIS CRASHES INTO HEATBED WHEN PRINT START November 07, 2012 11:58PM |
Re: Z AXIS CRASHES INTO HEATBED WHEN PRINT START November 08, 2012 05:02AM |
It sounds like you are taking care of manually homing and setting the z height. If that is the case, then you want to make sure that the slicer doesn't add any home commands. G28 is the home command.
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Z AXIS CRASHES INTO HEATBED WHEN PRINT START November 08, 2012 07:16AM |
Re: Z AXIS CRASHES INTO HEATBED WHEN PRINT START November 12, 2012 12:15PM |
Re: Z AXIS CRASHES INTO HEATBED WHEN PRINT START November 12, 2012 12:44PM |
Re: Z AXIS CRASHES INTO HEATBED WHEN PRINT START November 12, 2012 12:52PM |
Re: Z AXIS CRASHES INTO HEATBED WHEN PRINT START November 12, 2012 12:57PM |
Re: Z AXIS CRASHES INTO HEATBED WHEN PRINT START November 12, 2012 01:49PM |
Re: Z AXIS CRASHES INTO HEATBED WHEN PRINT START November 12, 2012 02:57PM |
