Firmware or Motherboard issues? April 07, 2022 03:42PM |
Printer is now online. Marlin bugfix-2.0.x echo: Last Updated: 2021-10-04 | Author: (ARS) echo: Compiled: Mar 31 2022 echo: Free Memory: 2359 PlannerBufferBytes: 1632 echo:V85 stored settings retrieved (676 bytes; crc 45991) Testing X connection... Error: All LOW Testing Y connection... Error: All LOW Testing Z connection... Error: All LOW Testing E connection... Error: All LOW >>> m122 SENDING:M122 X Y Z E Enabled false false false false Set current 500 500 530 514 RMS current 897 897 508 508 MAX current 1265 1265 716 716 Run current 29/31 29/31 16/31 16/31 Hold current 29/31 29/31 16/31 16/31 CS actual 0/31 0/31 0/31 0/31 PWM scale 0 0 0 0 vsense 0=.325 0=.325 0=.325 0=.325 stealthChop false false false false msteps 256 256 256 256 interp false false false false tstep max max max max PWM thresh. [mm/s] OT prewarn false false false false triggered OTP false false false false off time 0 0 0 0 blank time 16 16 16 16 hysteresis -end -3 -3 -3 -3 -start 1 1 1 1 Stallguard thrs 0 0 0 0 uStep count 0 0 0 0 DRVSTATUS X Y Z E sg_result 0 0 0 0 stallguard fsactive stst olb ola s2gb s2ga otpw ot Driver registers: X 0x80:00:00:00 Y 0x80:00:00:00 Z 0x80:00:00:00 E 0x80:00:00:00 Testing X connection... OK Testing Y connection... OK Testing Z connection... OK Testing E connection... OK ok P15 B3
Connecting... start Printer is now online. Marlin bugfix-2.0.x echo: Last Updated: 2021-10-04 | Author: (ARS) echo: Compiled: Apr 4 2022 echo: Free Memory: 2359 PlannerBufferBytes: 1632 echo:V85 stored settings retrieved (676 bytes; crc 45991) Testing X connection... Error: All LOW Testing Y connection... Error: All LOW Testing Z connection... Error: All LOW Testing E connection... Error: All LOW ok P13 B1 ok P13 B2 ok P13 B1 ok P13 B2 >>> m122 SENDING:M122 X Y Z E Enabled true true false false Set current 500 500 530 514 RMS current 497 497 508 508 MAX current 701 701 716 716 Run current 29/31 29/31 16/31 16/31 Hold current 29/31 29/31 16/31 16/31 CS actual 29/31 29/31 0/31 0/31 PWM scale 0 0 0 0 vsense 1=.18 1=.18 0=.325 0=.325 stealthChop false false false false msteps 16 16 256 256 interp true true false false tstep max max max max PWM thresh. [mm/s] OT prewarn false false false false triggered OTP false false false false off time 3 3 0 0 blank time 24 24 16 16 hysteresis -end -2 -2 -3 -3 -start 6 6 1 1 Stallguard thrs 0 0 0 0 uStep count 904 248 700 1023 DRVSTATUS X Y Z E sg_result 72 51 0 0 stallguard * * fsactive stst olb * ola * s2gb s2ga otpw ot Driver registers: X 0x81:1D:00:4A Y 0x81:1D:00:38 Z 0xE0:00:00:00 E 0x80:00:00:00 Testing X connection... OK Testing Y connection... OK Testing Z connection... OK Testing E connection... OK ok P15 B3
