Can you help me with toothed belts
Posted by keithCl
November 08, 2012 07:37PM
Hi all! I could really use some help
i'm building my first reprappro mendel. and i'm having a problem with my toothed belts. neither the x or y axis belts run true. the belt moves from side to side on the bearings of the idlers. here is a link to two videos showing the problem [www.youtube.com] and [www.youtube.com] anyone have some advice??
Re: Can you help me with toothed belts
November 09, 2012 07:07AM
You can adjust the squareness of the X axis by adjusting the screws that bear on the end of the X axis smooth rods which should sort out the x axis.
The Y axis can be adjusted by moving the bearing and the motor from side to side and also by angling the motor slightly.
I was sceptical whilst building but I have had no problems in use.
November 09, 2012 10:45AM
thanks MarkMarsh.
I'll give that a go. It's driving me mad. Couldn't figure out what was causing it.
November 09, 2012 09:19PM
The other thing to do is to fit two 608 bearings for each idler rather than one. The belt will run in the middle of them. You won't need fender washers around them, which the belt just rubs on anyway.
November 10, 2012 10:27AM
I heard the two bearings might work. Gotta find my old skateboard. Just moved house so everything is all over the place.
Thanks for the advice
