Slic3r Gcode not starting print
Posted by kwdelre
Re: Slic3r Gcode not starting print
November 21, 2012 04:24PM
In Slic3r if you set the temperature to 0 it will expect you to have set the temperature manually and will not insert the 'wait for temperature' command in the gcode.
I have a similar problem with an older Gen6 board. The temperature monitor varies by +/- 10 degrees between readings, so it was never stable enough for the firmware to recognise it was ready. Setting it manually and using 0 got around that.
Geoff
November 21, 2012 08:12PM
> Geoff
Ahhhh Geoff, very good point. Thanks!
