geoffd Wrote:
> In Slic3r if you set the temperature to 0 it will
> expect you to have set the temperature manually
> and will not insert the 'wait for temperature'
> command in the gcode.
> I have a similar problem with an older Gen6 board.
> The temperature monitor varies by +/- 10 degrees
> between readings, so it was never stable enough
> for the firmware to recognise it was ready.
> Setting it manually and using 0 got around that.
> Geoff
Ahhhh Geoff, very good point. Thanks!
