So, we intend to move 4 NEMA17 stepper motors using 4 TMC2209 Motor drivers. By mistake I kept the board on a conductor(the board has pins protruding out at the bottom) and the board was shorted. The CH3403 chip was burnt(visibly), but I was not sure what other parts of the board was damaged. When the board was shorted, the motor drivers were plugged in and the motors were connected and a 12V power supply was given to the board, also the board was connected to the laptop with USB.
We bought a new MKS Gen L board(but I am still using the old 4 motor drivers), the board seems to work(LEDs are glowing as they should), but when I connect all 3 or more motor drivers to the board, the red led goes off(when the board is connected only with the laptop using a usb cable, the red led doesn't go off when 12V power is being supplied). Even when I am using only 1 motor driver, the red led keeps glowing(when the board is connected only with laptop), the blue green LEDs also blink, indicating data is being transmitted(when I upload my code), but the motors are not running. Also the drivers are getting very very hot.
I am confused whether the new board I ordered is faulty or the 4 motor drivers were also damaged. Should I buy new motor drivers or should I get my board replaced.
Is it possible that my motors were also damaged?
Can anyone help me on how to test it?
Edited 1 time(s). Last edit at 12/29/2022 01:08AM by ph20b003.
