Layer Thickness improvement
Posted by nefermu
November 24, 2012 03:16PM
Hi
I have a prusa iteration 2 and it is capable of printing 0.20 mm layer thickness. Are there any tips to reduce this number
[www.3byazici.com]
[3dprintertr.com]
Re: Layer Thickness improvement
November 24, 2012 06:27PM
Before reducing the layer thickness, you should do something about all the bumps on the surface which were probably due to pauses while printing. Are you printing from SD card? I'm guessing that you're not and you have some communication problem between your PC and your printer controller. It can also be due to you PC not supplying the g-codes to the printer fast enough.
November 25, 2012 01:32AM
Thanks I am not printing from SD Card. I am open to all suggestions. I really want to improve print quality.
I am using sanguinololu, sli3r, prusa i2, 3mm abs, no heated bed, printing temp 258 C, 0.4mm nozzle,
Instead of heated bed, I am using PVC tape or ABS juice.
yoda
wedge
A video of printing
vase video
November 25, 2012 02:19AM
I have iteration 2, and i've had it work at 0.05 mm before.
Turn up the temperature 10-20 degrees, and increasing the movement between print areas (speed and acceleration) dramatically, to prevent ooze.
And for the record, almost nothing is worth printing less than 0.1 mm per layer.
November 25, 2012 08:30AM
@nefermu - How does the extruded filament look when you extrude in air? I don't see signs of pauses in the video but your walls are very rough with a lot of bumps. Perhaps there's something wrong with your hot end. If it looks smooth in air, perhaps your extruder hobbed bolt is slipping on the feed. Do you see plastic dust on the hobbed bolt?
Also, 258C is a very high hot end setting. Do you have the right thermistor table loaded on the firmware? If so, you should lower it down. With the corrected thermistor, ABS should be around 230C.
Edited 1 time(s). Last edit at 11/25/2012 09:17AM by brnrd.
November 25, 2012 01:57PM
Thanks for help,
Yes there is ABS dust on extruder and I will check thermistor table.
November 26, 2012 12:25PM
My thermistor is
EPCOS B57560G104F
and here is the firmware table. I have compared with wiki but numbers are completely different. I am not sure if my tables are that wrong
#if (THERMISTORHEATER == 6) || (THERMISTORBED == 6) // 100k Epcos thermistor
#define NUMTEMPS_6 36
const short temptable_6[NUMTEMPS_6][2] = {
{28, 250},
{31, 245},
{35, 240},
{39, 235},
{42, 230},
{44, 225},
{49, 220},
{53, 215},
{62, 210},
{73, 205},
{72, 200},
{94, 190},
{102, 185},
{116, 170},
{143, 160},
{183, 150},
{223, 140},
{270, 130},
{318, 120},
{383, 110},
{413, 105},
{439, 100},
{484, 95},
{513, 90},
{607, 80},
{664, 70},
{781, 60},
{810, 55},
{849, 50},
{914, 45},
{914, 40},
{935, 35},
{954, 30},
{970, 25},
{978, 22},
{1008, 3}
November 26, 2012 01:31PM
You're using the wrong thermistor table. You need to use the one here or generate one yourself using the correct parameters from that table. Here's how you can use the table from the wiki into the thermistortables.h.
#define NUMTEMPS_6 20
   {1, 864}, // 864.165363324 C
   {54, 258}, // 258.53991594 C
   {107, 211}, // 211.310066205 C
   {160, 185}, // 185.861725716 C
   {213, 168}, // 168.31793816 C
   {266, 154}, // 154.754297589 C
   {319, 143}, // 143.52544406 C
   {372, 133}, // 133.784751118 C
   {425, 125}, // 125.033500921 C
   {478, 116}, // 116.945124847 C
   {531, 109}, // 109.283980973 C
   {584, 101}, // 101.861768746 C
   {637, 94}, // 94.5095302806 C
   {690, 87}, // 87.0542728805 C
   {743, 79}, // 79.2915563492 C
   {796, 70}, // 70.9409729952 C
   {849, 61}, // 61.5523326183 C
   {902, 50}, // 50.25271896 C
   {955, 34}, // 34.7815846664 C
   {1008, 2} // 2.86606331838 C
It would probably be better to include more points but this would be better than what you're using now. Perhaps someone can share a better table for that thermistor.
