Wrong Object Height
Posted by 13asilis
Wrong Object Height
November 25, 2012 05:07PM
Hi guys,
I have a really weird problem with my Z-object height ...
After a Marlin firmware update (actually after losing my firmware settings and setting it all up again), my Z object height is completely off...
I'm using M8 screws with 1/16 microstepping and direct drive and have the z-steps set to 2560 steps/mm in the firmware! When I ask the z-axis to move it moves the exact demanded length!
But when I try to print an object, the object height is completely off!
In the attached image you can see 3 gears:
Middle: older print which was printed correctly (~11mm height)
Right: new print with 2560 steps/mm -> resulting height is about 8.7mm!
Left: adjusted z-steps (about 3200 steps/mm) -> resulting height is about 13.3mm
The layer height is set to 0.2mm with a 0.35 nozzle!
Using newest Marlin, Slic3r 0.8.4 and LCD panel with SD card! (Prusa i2)
Any ideas?
Oh and another minor problem which is kind of annoying:
My printer doesn't finish the last few moves! in the attached picture you can see that a few lines from the last layer are missing, it just stopped before finishing all the moves!
Again, anyone having the same problem or even a solution for it?
Regards,
Basilis
Re: Wrong Object Height
November 26, 2012 02:04PM
I would suggest checking the g-code you are running, to make sure the slicer is doing what you expect.
November 26, 2012 05:57PM
Thanks a lot for the reply, I did check it and it moves the demanded length per layer (at 0,2mm layer height always 0.2mm!)
I got a tip from a friend of mine today, he told me that I should check if the Z-axis was always turned on in the firmware - because turning it off may result to it slipping downwards while moving fast! I'll give that a try and report back!
EDIT: OK I've checked and the "disable z-axis when not in use" is false .. so I suppose it's turned on at all times ...
I really need some help guys, I have absolutely no clue what to do :_(
Edited 1 time(s). Last edit at 11/26/2012 06:14PM by 13asilis.
November 27, 2012 09:04AM
Are you sure the Z axis can achieve the feedrates commanded in the G-code? With 1/16 microstepping and a 16 MHz controller, maximum feedrate can be as low as 100 mm/minute (1.7 mm/s) on this axis.
When commanding an axis to go faster than it can, it'll move parts of the acceleration and parts of the deceleration ramp, only, missing some of the steps in between.
And a note: for testing movements it isn't neccessary to put filament in. winking smiley
November 27, 2012 11:35AM
Make sure the z-rods are not slipping compared to the stepper motor. I had that problem on one side only so it was obvious after a little while, because the whole x axis carriage started to tip. But if both are slipping, then you might not notice. I am using plastic tube as my z axis couples, so I added zip ties and oiled the threaded rod.
November 28, 2012 02:23PM
Hi guys thanks a lot for the help!
I've managed to resolve the problem by decreasing the ZJERK from 0.4 to 0, now the object height is spot on!
I've noticed a different problem now:
I can't really classify it, if you look at the picture you can see some weird traces left behind the printed circle ... it seems to me that when changing direction the extrusion is a bit irregular, is that related to the XYJERK maybe? the XYJERK is currently at 10...
open | download - IMG156.jpg (532.7 KB)
November 28, 2012 03:31PM
Do you have springs on your bed? This might be vibration of the y carriage if that wall is along the x axis.
November 28, 2012 04:17PM
my bed does have springs, but they are tidened down and it looks rather stable i have to say ...
the problem occurs in both directinos .. the picture shows only 1 side of the object, but the same thing happens in X as well as Y direction!
November 28, 2012 05:14PM
You might want to tighten your belts. I had a similar problem that I solved by tightening my belts. Watch the belts when it prints, on my I could see them bounce up and down a lot when the nozzle changed directions. Not sure if you are having the same problem.
November 28, 2012 06:09PM
It's definitely from vibrations when the x or y axis stops. Remember that to make a 90 turn at the corners, one of the axes has to stop and the other one starts. When the vibration occurs along the axis that stopped and it results in the wavy walls that look like damped oscillation. If you slow down the print, the vibration frequency would change and if you slow down enough, it should eventually go away. You can also reduce it by decreasing the x and y acceleration or the xy jerk in the fw.
December 05, 2012 04:14AM
Hi guys, thanks a lot for the help!
I've managed to get rid of the weird oscillating traces of edges by turning the acceleration way down .. to about 500! (on the X and Y axis) ...
After turning the XY-Jerk down as well, I have the feeling that too much material is being put onto the edges, leaving weird pimples that stick out in the edge-area! I've turned the Jerk up to 30 by now but maybe I do have to go up again with the acceleration?
