J-Head set screw - where is it supposed to be
Posted by tprime
November 26, 2012 07:41AM
Hello,
I've recently purchased a J-head MK/IV (alu, not brass) in europe and have trouble with it having a very high resistance - I need too much force
to push out my plastic.
The documentation seems to mention a set-screw that's supposed to hold the PTFE in place? Where's that supposed to be located - I can't
tell from the pictures, nor find it on my J-Head. The only place I seem to have a grub-screw hole is on the resistor side - which I guessed was to make sure the resistor
was in decent contact with the hot end.
Thanks,
So long,
Tyberius Prime
Re: J-Head set screw - where is it supposed to be
November 26, 2012 08:33AM
It's supposed to be in PEEK nozzle holder, on the side with extruder mounting groove, and filament passes right through it.
EDIT: attaching link to picture
Edited 1 time(s). Last edit at 11/26/2012 08:37AM by miso.
November 26, 2012 08:47AM
So I guess it is missing on mine then.
Stil ldoesn't quite explain why, if I fix the tubing at the top with a washer it requires so much force.
My barrel is 5mm, with a 4.75mm teflon tube - not 6.35/6mm.
Drives me nuts winking smiley Tried pretty much everything I could find in the forums, I am cooling it, I've cleaned the nozzle,
it's hot enough, still I can't reliably print faster than 15mm/s sad smiley
November 26, 2012 01:29PM
you sure you did not buy a knock-off ?
November 26, 2012 06:27PM
@Asger: not at all. J-Heads are a tiny bit hard to source in europe - I wouldn't mind it being produced locally, it's an open source design after all.
But: I can't get it to flow properly. I've cleaned it twice, tried assembling in serveral times now. My last idea is to wrap the PTFE liner in teflon tape,
to exclude that it's leaking - it seems to be pushing a tiny bit of material to the outsides of the tube (and then on into the threading...).
There is another guy on ebay giving the seller good ratings on the J-head, commenting he fixed a bit of leaking with teflon tape.
Otherwise, I'm fresh out of ides. I''ve even made a new alu 'top' with a 3.5mm hole to keep the liner in place.
November 26, 2012 08:28PM
Hello,
In all probabiliy, there are one or two problems.
1. The nozzle orifice length could be too long. This will increase the extrusion pressure.
2. The other issue, that happened primarily with the Mk IV-B and earlier designs, is that it is possible for the PTFE tubing to be constricting at the junction with the brass. This can happen if the hollow set-screw is too tight.
As I have not personally seen this particular clone, I suppose it is possible that there are other possible issues.
Regards,
Brian
Edited 1 time(s). Last edit at 11/26/2012 08:31PM by reifsnyderb.
November 27, 2012 03:22AM
Thank for chiming in Brian - I appreciate all the work you put in designing these!
2. I believe I can exclude. The PTFE liner flushes with the top of the PEEK (no set screw) without forcing it, then there's basically just a plate above it holding it
in place. If I take it out, by itself, it slides nicely along the filament.
I've also tried adding a tamper with a pencil sharpener, which should give it room to expand if it needs to.
Hm. Perhaps the ID of the liner is to small - large enough when cold, but constricting when it get's hotter?
I gotta measure this tonight!
So long,
Tyberius Prime
November 27, 2012 03:27AM
> all.
> tape,
> liner in place.
I have to call BS on "J-Heads are a tiny bit hard to source in europe"
firstly, reifsnyderb charges 3.75$ for international shipping and the actual hotend is 54,99$
I too live in Europe, and have yet to see a source offering the hotend and shipping cheaper
November 27, 2012 06:20AM
> 54,99$
Depends on how you define 'tiny bit hard'.
Dealing with customs (+19% price increase here) and waiting 4 weeks (or longer if you're in the unlucky 5%), plus the risk of an uninsured international package with USPS 'International first class' is a tiny bit hard to me.
Though admittedly not difficult.
I have a t-shirt seller that claims that shipping method has a 2% loss rate for them, right on their website. Earlier on it said 'they ship them with oxen winking smiley
52.55 EUR from Denmark, here in 2 days was an a competitive offer. Negligible cheaper (about 1 EUR), but much faster.
Plus, it offered both 3mm and 1.75mm in one hot-end, simply by adding another liner.
Though of course if I factor in how not-well it is working...
November 27, 2012 06:54AM
> > 54,99$
> source
> oxen winking smiley
> working...
Sounds like you are in Germany? I am in Denmark 25% here plus various other evil fees, granted the lead time is longer, but having purchased 4 j-heads now from hotends.com I've never paid a cent of tax on any of the shipments, neither has any of my reprap-ing friends. Maybe it's the fact that it's shipped like a letter and not a parcel (securely packaged in bobblewrap) not much that can break inside even if dropped.
Who did you purchase from in Denmark, thy3d? captain-slow? reprap.me?
November 27, 2012 07:13AM
Yeah Germany. The local customs work out to a 50/50 chance in the long run for me.
(And my old V5 hotend broke, and I wanted to get back into printing and prevent the issue at the same time,
hence the emphasis on prompt delivery. Well, that went well... )
I bought it from the later shop you mentioned.
November 27, 2012 11:36AM
Hello,
A Mk IV-B without a setscrew to hold the PEEK in place? The Mk I had the liner held in place by the extruder (No hollow set-screw.) and the major improvement, of the Mk II, was to add the set-screw. Without the set screw, a gap can form in between the liner and brass. This could also cause problems.
If the ID, of the liner is too small, you may be able to enlarge it with a drill bit.
Regards,
Brian
> above it holding it
> it needs to.
> get's hotter?
> So long,
> Tyberius Prime
November 27, 2012 11:54AM
Yes indeed, it was sold as a MK IV (no cool smiley, and even listed a hollow set-screw.
Unfortunately, I didn't catch on to that right away, since none of the pictures on the wiki show the top of the J-head.
I presume it's a combination of this thing not having the ridge for the line to sit on (the 'melt chamber') nor a set screw.
I keep it in place with a small aluminum plate, but that's a way worse solution than the set screw.
Thanks for all your input!
December 03, 2012 06:27AM
Hello tprime,
I bought two of these from 'RepRap me' (via eBay) and tried them at the weekend, had a similar experience to you.
I have used tens of J-heads (as far as I know all of them were made and came from Brian, via a number of UK re-sellers) and had no issues at all with any of them even after 9 months of every-day printing.
This model of the j-head design from 'RepRap me' does not have the PTFE liner set-screw fitted. The loose double barrel liners seem to work, but something is making the force required to extrude really massive even when it's clamped at the top of the nozzle with a plate, resulting in a very poor flow and extremely low speed of operation. (and a stalling and over worked Extruder motor).
They both leak (a lot) even with PTFE sealing tape they still leak after only 40+ mins of operation.
Original 'RepRap me' j-head design -
If this is your only experience of a J-head, it's not typical, I can't use this design as it stands, I'll see if 'RepRap me' has any ideas to make it work, but I doubt it.
I can add a few images I had over the weekend of the failures for both nozzles, if anyone is interested.
I have just contacted the seller on eBay and explained the problems, and also my testing results. It looks like they are aware of at least some issues, as an alternative design is also now up on eBay - anyone seen this design before? does it work?
'Alternative design?' -
The alternative design is using high temperature glue around the nozzle and aluminium head, not something I would expect to see, so I guess the sealing issues may still not yet be resolved. This design also claims to have both 1.75mm and 3mm filament options so I guess as it's using a set-screw they must now have to use two different liners and not one inside the other? - If not I'm not sure how else it's going to work?
I will let you know how they respond to my questions about this alternative J-head design, and if I get a satisfactory conclusion.
Rich.
[richrap.blogspot.com]
December 03, 2012 06:53AM
@Rich: Reprap.me has offered to replace the j-head for one with the set screw, presumably because the ebay auction claimed it had one and I pointed this out under the danish 'right of complaint' law.
I'm still not certain what's actually wrong with the first one if you clamp the teflon liner externally.
Perhaps it's cut too short for that.
The PTFE liner on the alternative design looks awfully short as well.
We'll see if it has a 'melt chamber'/ridge for the liner to sit.
The thermal glue has me worried - I don't think that you can dismantle and reassemble this thing in
case of jam.
I'll report back once the replacement is here.
December 03, 2012 07:15AM
There's article on jheadnozzle blog about some design from ebay, looking similar to your's. It points out so there's also problem with heater block design.
jheadnozzle
There are 3 major problems with it, however. The first is that the interior is based upon the original design and does not have a melt chamber section. So, the liner goes all the way to the tip. Another issue is that the nozzle orifice is supposed to be 0.50mm; however, it is closer to 0.53mm in diameter. The final issue is that the nozzle orifice length is a whopping 3mm long. I would bet that the extrusion pressure is pretty high.
December 03, 2012 08:52AM
@tprime - Thanks for the update. 'RepRap me' has refused to refund or replace them for me, stating the 14 day period has expired, this is true, but these devices simply do not work as implied by the good name they are using to promote (J-head). They are certainly not like any j-head I have ever used.
I sent another two messages via eBay, pointing out the statement that a hollow set screw is in the description, but not fitted or even designed into the product. I have asked them to reconsider. If I still do not get any success I'll take it further.
I't a shame, I have bought things in the past from them, and didn't expect such poor service when there is a clear problem with a product they have shipped out to many people.
I'll let you know how this pans out.
@miso - Thanks for the article link. This at least explains why the extrusion force is so extremely high. This hot-end is basically useless in it's design, I can't imagine anyone being able to print with it, or wanting to wait while it slowly extrudes and eventually leaks.
I have just placed an order directly with Brian at Hotends.com, for three nozzles of his newer MK V-BV design, I have total faith in Brian, so I'm sure this will get me back on track for my new machine prototypes.
For the record the reasons I was tempted to try them out were - Aluminium nozzle (light-weight) and 1.75mm filament option (these two combinations have been hard to get over here in the UK)
Very disappointed with 'RepRap.me' - This one is not over yet.
Rich.
December 03, 2012 09:25AM
@Rich: Sorry to hear that you're having trouble returning them. He hasn't much choice under EU consumer protection laws though.
Magic words seem to be 'right of complaint', 'not as advertised' and (and fixing a time limit).
The extrusion hole being too long might be the issue - can't measure mine any more hot smiley. I guess it could be salvageable by increasing
the drill depth on the other side. I also presume the extreme force necessary influences the leaking.
I'm going to spend some time experimenting with the 'organ pipe hotend' while waiting for my replacement - and
if that one doesn't work out either, I'll bite the bullet on importing from the US.
December 03, 2012 10:03AM
@tprime - After two further messages I had a message back from 'RepRap.me' offering a refund if I return them, which I will do tomorrow. I will update this when I get my refund or if I get any other issues.
The high pressure required for this design makes it impossible for practical use. I was running a geared NEMA17 stepper at 1.3A and with 1.75mm filament, it would skip steps at speeds above about 15mm/sec (Extremely slow). and then leak.
If you plan to run a direct drive stepper extruder, NEMA14 motor or 3mm filament, you basically have no chance at sensible extrusion speed with this design.
And this is going to be why the hot-end leaks, even at low speeds.
People will try to increase the temperature to overcome the pressure problem, but this just makes the problem worse and the plastic more runny, it will just leak faster.
A 'normal' MK-IV J-Head can extrude at +80mm/sec with a 0.4 or 0.5mm nozzle, 3mm filament and a Nema17 stepper set to under 1A without any problems at all.
Well, lessons learnt here, I hope I do get my refund...
Everyone else beware of these hot-ends - if they are coming out of China (or anywhere else) without any real-world testing before shipping an unproved design, this is what you get, along with a lot of people in the supply chain also very unhappy.
Happy extruding everyone.
Rich.
December 03, 2012 12:19PM
> other issues.
> even at low speeds.
> problems at all.
> refund...
> Rich.
[forums.reprap.org]
[groups.google.com]
maybe it's time to give reprap.me bad reviews on the wiki?
December 11, 2012 06:23PM
My replacement arrived. It now has a set screw, it does not show the red thermal glue seen in some photos - and it still requires way too much force to extrude.
As for the 1.75 conversion, apperantly there is no second set screw, but simply a longer piece of inner tubing. I don't quite see how that's supposed to work.
December 18, 2012 08:00AM
Hi tprime - An update from me on this -
I had my full refund from Peter at reprap.me (snipermand on eBay).
Peter is aware of the issues and is discussing these with his supplier. I have also made Peter aware that only adding the set screw does not resolve most of the fundamental issues with this hot-end design, the main problem is still the extremely long internal nozzle length of around 3mm - it should be more like 0.5mm for any level of sensible extrusion speed being driven by most normal extruders.
Let us know how well the replacement works for you, If the nozzle hole is still very long you will be very speed limited and may still get leaks if you push it too hard.
Hot-ends are not all about speed, I'm very happy to see a slower speed hot-end that has less ooze and die swell. But general purpose hot-ends need to be able to print reasonably fast at this stage in the game.
My official J-head MK V-BV order also arrived from Brian at www.hotends.com - these are fantastic, slightly shorter and lighter than all the previous versions I have used to-date, very well made and clean machining all over.
The nipple end is also gone, this is another good move and should generally give less problems when printing.
I'm using a cartridge heater and thermocouple, gets up to temperature in about 18 seconds. (Remember to run M303 to calibrate your new hot-end PID settings everyone).
I now have the 0.4mm MK V-BV nozzle (1.75mm filament) currently fitted into a Rostock, printing VERY fast, so as soon as I get that settled in I'll post a few pictures.
I have a 0.35mm version (1.75mm) I'm going to use for an upgrade in the Tantilus. And finally a 0.5mm version for a new machine.
Printing over Christmas should give them a very good test, but already I'm impressed with it's performance in Rostock (bowden configuration)
With metal pulleys, good belts and a strong frame, most DIY 3D printers are now good enough to get excellent results by many people, the hot-end, extruder and filament drive mechanism are still (in my opinion) the most critical part of most 3D printers, make sure you choose well and if in doubt ask others how well they perform for what you want to do with them.
When you get something that seems to work well, you can start to compare alternatives, don't assume what you have is the best it can be. I would hope anyone developing hot-ends does some real research and at least benchmarks against some designs the community feel to be working well before releasing them for sale.
Rich.
December 18, 2012 09:31AM
I haven't talked to Peter yet - last event was that my Greg's extruder developed a lot of play in it's clamp - probably due to needing way
to much force to push the filament out...
December 30, 2012 06:09PM
I've managed to salvage the newer one (with the set screw) by drilling it out a couple of mm, thereby shortening the length of the channel.
Quite a bit of plastic swell (0.35 ->0.5mm) now, but at least it seems to be extruding decently when printing at 60mm/s (knock on wood winking smiley ).
