J-Head set screw - where is it supposed to be November 26, 2012 07:41AM |
Re: J-Head set screw - where is it supposed to be November 26, 2012 08:33AM |
Re: J-Head set screw - where is it supposed to be November 26, 2012 08:47AM |
Re: J-Head set screw - where is it supposed to be November 26, 2012 01:29PM |
Re: J-Head set screw - where is it supposed to be November 26, 2012 06:27PM |
Re: J-Head set screw - where is it supposed to be November 26, 2012 08:28PM |
Re: J-Head set screw - where is it supposed to be November 27, 2012 03:22AM |
Re: J-Head set screw - where is it supposed to be November 27, 2012 03:27AM |
Re: J-Head set screw - where is it supposed to be November 27, 2012 06:20AM |
Re: J-Head set screw - where is it supposed to be November 27, 2012 06:54AM |
Re: J-Head set screw - where is it supposed to be November 27, 2012 07:13AM |
Re: J-Head set screw - where is it supposed to be November 27, 2012 11:36AM |
Re: J-Head set screw - where is it supposed to be November 27, 2012 11:54AM |
Re: J-Head set screw - where is it supposed to be December 03, 2012 06:27AM |
Re: J-Head set screw - where is it supposed to be December 03, 2012 06:53AM |
Re: J-Head set screw - where is it supposed to be December 03, 2012 07:15AM |
jheadnozzle
There are 3 major problems with it, however. The first is that the interior is based upon the original design and does not have a melt chamber section. So, the liner goes all the way to the tip. Another issue is that the nozzle orifice is supposed to be 0.50mm; however, it is closer to 0.53mm in diameter. The final issue is that the nozzle orifice length is a whopping 3mm long. I would bet that the extrusion pressure is pretty high.
Re: J-Head set screw - where is it supposed to be December 03, 2012 08:52AM |
Re: J-Head set screw - where is it supposed to be December 03, 2012 09:25AM |
Re: J-Head set screw - where is it supposed to be December 03, 2012 10:03AM |
Re: J-Head set screw - where is it supposed to be December 03, 2012 12:19PM |
Re: J-Head set screw - where is it supposed to be December 11, 2012 06:23PM |
Re: J-Head set screw - where is it supposed to be December 18, 2012 08:00AM |
Re: J-Head set screw - where is it supposed to be December 18, 2012 09:31AM |
Re: J-Head set screw - where is it supposed to be December 30, 2012 06:09PM |
