solved // hotend and bed not heating up
Posted by ripcurl
November 30, 2012 05:11PM
hi everyone I cant seem to get the hotend going its been a long struggling build but im almost there, I finally got all the xyz motors to work ,i have mechanical endstops x3 to work too and both thermistors for hotend and bed are working ,when i touch the thermistors they react againt my body heat great ,but hotend will not work im running marlin for arduino lcd + clicker which all works im using pronterface for this.
my hotend is wired into D10 as drawing its not clear what is plus and minus theres two for plus and two for minus
heatbed doing the same thing will not heatup
hotend from ebay [www.ebay.co.uk]
ramps kit and lcd from here [www.ebay.co.uk]
id like to just add i do have problem with my ramps smoking once ive replaced aduino mega 2560 completly
any help would be appreciated dave
Turns out to be my Ramps board delaminated itself from an earlier test
Hope this helps someone else
dave
Edited 8 time(s). Last edit at 12/01/2012 08:09AM by ripcurl.
Re: hotend not heating up
December 01, 2012 02:09AM
#define HEATER_0_MINTEMP 5
if mintemp is below 5 it will not turn on, it will assume that there is a disconnected thermister. temp tables are questionable on marlin, what thermister are you using, and what is the starting temp?
// 34 = RAMPS 1.3 (Power outputs: Extruder0, Extruder1, Bed)
#define MOTHERBOARD 33
also shouldnt' it be motherboard 34, not 33?
December 01, 2012 04:36AM
thermistors are showing room temprature 19 to 20 degrees when i hold tip it goes up
ill also try 34
and maybe disable min temp to try out ill keep updated but im wondering if i can put 12v directly to see if hotend works if that is a good way to test what do you think?
dave
update ive tried reccomendations still no joy im at a lost now maybe a fuse on ramps board needs changing im picking at straws now
latest photos showing setup and no change in temp
Edited 3 time(s). Last edit at 12/01/2012 05:34AM by ripcurl.
open | download - IMG_0087.JPG (66.1 KB)
open | download - IMG_0084.JPG (54.8 KB)
open | download - IMG_0085.JPG (58.8 KB)
