glue pla
December 12, 2012 07:04AM
hi all,
was a bit confused from reading posts how successfully i could glue pla so i did some gluing and here are the result for any interested parties:
selleys fix n go superglue:
glued two flat (bed side) pieces together - very strong join - cannot force apart
selleys all plastics & toy glue
same as above
selleys araldite
two flat sirface - good bond - failed when i forced it and glue peeled off smooth surfaces - would have been ok if not forced
two rough surfaces ie. top layer - good bond - failed when i forced it - would have been ok if not forced
price in AUD
selleys glue plastic $4.80/3ml $1.60/ml
selecy fix n go supaglue $2.59/3ml $0.86/ml
selley araldite $10.29/24ml $0.42/ml
so araldite is pretty good and cheap and would work best i think if any sort of gap between surfaces
otherwise superglue was rock hard join
now want to glue the PLA to mild steel - any suggestions, predictions, bets ???
roger
Prusa 'Explorer' (3dStuffMaker), GEN6, J-head Mk III-B, Bowden Extruder, Marlin 1.0.0 RC2, Repitier-Host V0.84 and Slic3r 0.9.8, PLA. Live at Victoria, Australia.
Re: glue pla
January 07, 2013 07:39PM
Superglue sticks well to steel, I suspect that'll work well. When I want to glue things together I often add a number of small holes to the surface to be glued to allow araldite to grip better - if you get the glue into the holes and use good araldite it makes a crazy strong bond.
