Abs bridges
December 14, 2012 05:18PM
Can I get some helpful suggestions on printing bridges with abs with a j-head IVb
I'm printing abs at 140c with heated bed at 110c on pet covered glass
I've tried fast and slow setting in slic3r but get the same sagging bridges as always
Tried using a fan on th bridges which helps a fair bi but the causes prints to warp horrible
Can you give some examples of settings and set ups please
Re: Abs bridges
December 14, 2012 05:44PM
You need to stretch it more by using lower layer height / filament width relative to the nozzle size.
Re: Abs bridges
December 14, 2012 08:29PM
With a 0.4mm J-head I normally do 0.4mm layers with W/T = 1.5. If I want long bridges I use 0.35mm layers.
Re: Abs bridges
December 15, 2012 04:05AM
Currently running at 0.3 layer height as I'm printing prusa3 parts
What speed would you say use in slic3r?
Re: Abs bridges
December 15, 2012 06:16AM
What is the filament width?
I don't use Slic3r, too many bugs!
Re: Abs bridges
December 15, 2012 08:12AM
Do you mean in the interface, or in the GCode? What sort of bugs?
Re: Abs bridges
December 15, 2012 09:05AM
It doesn't get the basic geometry right. Various versions have had different dimensional errors in the holes and the outlines and the latest ones have extra spikey bits added to the outlines. I follow the bug reports on github and it seems to be getting worse rather than better.
I prefer Skeinforge because the outlines and holes it produces in the gcode appear to be exactly the same as they are in the STL (offset by the half the filament width).
Edited 1 time(s). Last edit at 12/15/2012 07:29PM by nophead.
Re: Abs bridges
December 16, 2012 01:21PM
If you have to use Slic3r, use 0.7.2.
That one nails the geometry right.
Re: Abs bridges
December 16, 2012 01:26PM
lmoa this seem to have turned into a slic3r debate
solved my briding problem in slic3r now
completly turned off the fans for ABS
and dropped the bridge flow rate to 0.6 and bridge speed at 10mm/sec
seems to be working a treat now and does not lift at all when running the PET Glass at 110C
