Glue-Gun as Thermoplastic Extruder
October 19, 2008 08:26PM
It seems to me that the most obvious thermoplastic extruder has been overlooked
Re: Glue-Gun as Thermoplastic Extruder
October 19, 2008 08:47PM
Pheobot Wrote:
> (Please tell me if this is not a new Idea, and If
> anyone has done this could they please tell me how
> so I can get more ideas.)
It's not a new idea. Vik, iirc, on the core Reprap team explored the idea rather extensively back in 2005. Glue guns were what the Reprap project was working with before Dr. Bowyer developed the Mk II extruder at the end of 2005.
The advantage of the Mk II over commercial plastic welding machines using plastic welding rod was that it was tiny and required very little power to operate.
Don't get discouraged. Read back through the Reprap Blog and see if you see anything that we missed. There are undoubtedly plenty of things that we haven't seen from being too close to the problem. smileys with beer
October 19, 2008 09:39PM
Thanks for the reply.
It's just that getting a glue gun is alot cheaper then makeing a Mk II. but if the glue gun can't provide a good result then I'll have to try something new.
October 20, 2008 05:54AM
at 195 degrees celsius, you don't have to use "hot glue" as far as I can see....
If you can get the ABS (or any other plastic you want) in the right diameter, perhaps you could use the hot glue gun.
but... the big problem is that the mechanism used is not very easy to control....
I'm thinking that perhaps a motor with an arm and rod connection might work (thing of the way steam locomotives work by converting linear motion into rotary motion, but in reverse).
So if you had a stepper that had enough torque you could conceivably do this.
-Leav
sid
October 20, 2008 06:43AM
The thermoplast extruder is a very tricky thing to build especially without a lathe, so having some sort of "just hack a ...." would be a huge benefit indeed.
I recently bought a desoldering gun wich unfortunately has a very small inner tube (1.8mm) so no chance to feed our 3mm filament.
Now I ordered an incar soldering iron (12V 30W) wich I believe would be closer to our needs.
fiy a zhongdi zd-200
If everything goes well it has a hollow heater with an internal diameter of 6mm.
I also send an email to zhongdi corp asking them what would be necessary to custom build a heater for us (including a nozzle, thermistor, and matching brasstube) because the one from the desoldering iron is very well (farnell #1516018) except the small tube; maybe we can special order only "few" custom heaters.
'sid
[edit]
just fixed that ugly typo.. thanks forrest
Edited 2 time(s). Last edit at 10/20/2008 12:59PM by sid.
October 20, 2008 10:53AM
> build especially without a lace
> 'sid
And a "lace" is? confused smiley
October 20, 2008 11:31AM
pretty sure Sid meant a lathe. smiling smiley
I had acceptable results using the "no lathe" technique that was posted a while back; my first attempt was useable, and I suspect my next one will be even better. All you need is a hand drill, some small bits, safety glasses and patience. smiling smiley
Wade
October 20, 2008 12:33PM
Ah! Okay! I just wasn't connecting this morning. spinning smiley sticking its tongue out
I built a variation on the Mk II with an extruder barrel made from 5/32 hard copper tube. Works brilliantly.
[3dreplicators.com]
sid
October 20, 2008 01:04PM
Sorry, my fault..
Yes a lathe is what I wanted to say.. I'm unsure why a lace came out.
nevermind, go ahead.
Yes forrest I do have some brass tubing laying around but either I need to braze the nozzle (braze? not brace...? Uh now you got me again...)
or I'll have to tap a thread for the nozzle.
It has to be even easier than that.
'sid
October 20, 2008 01:14PM
Sid:
I use copper instead of brass for a couple of reasons. The first is that copper is worlds easier to BRAISE (nasty English language spelling conventions make about as much sense as the German habit of capitalising words in the middle of a sentence apparently at random) than brass. eye popping smiley
Because of that, braising a piece of thin brass sheet to the end of a thin-walled brass tube is nearly impossible because it is very difficult to get both parts to anything like the same temperature.
I hate the threaded nozzle and threading the extruder barrel into the PTFE and used a compression join instead. Works very well.
Forrest
I got me the brass tube because of two reasons,
first of all I didn't intend to braise the tubing in any way, but i was unsure if I maybe need to tap a thread
second, although I looked around I didn't find any copper tube with 3mm internal diameter and around 6mm outer diameter (different purpose)
And that's why I asked zhongdi.
The pictured replacement heater (without nozzle in the picture) costs about 5-7 Euros that's fairly cheap for a plug and play heater with the thermistor.
So if we could meet something close to that with readymade heater,
the rest is tightening screws so much easier than any other attempt to date. winking smiley
back to braise braze but not brace winking smiley
That one wasn't my fault! dict.leo.org told me that braze is correct
I guess you know better than me, but braze is what comes closest to the german word hartl
October 20, 2008 02:06PM
Both spellings are correct and used interchangeably. Probably, braze is less confusing because it has no parallel use as a term in cookery.
October 20, 2008 02:08PM
heh, yeah, I was just going to say something about turkey. Yum!
smiling smiley
sid
October 20, 2008 06:43PM
well in that case..
nothing more to say but:
we got far off topic winking smiley
Glue guns... glue guns... Oh yes,
Andreas is currently using a slightly modified glue gun
[forums.reprap.org]
Let's see how far he gets with it.
I am waiting for the 12V soldering irons I bought from ebay to see how far I'll get with these.
'sid
October 20, 2008 10:53PM
I can see how the glue gun's mechanics are all wrong for automatic use, but do you think that the heating mechanism could be modified to take a smaller diameter
sid
October 21, 2008 08:32AM
not all pheobot, there are glueguns for granules.
they are perfect for other granules like abs or pe winking smiley
'sid
October 21, 2008 10:30AM
You don't need a lathe - The barrel is small enough that you can do everything you need to by loading it into a hand-held drill.
I made several that way, worked great. Though I must admit I haven't squirted any plastic yet...
It sounds much harder than it is. I didn't even need a drill-press.
I'm building it with Baling Wire
October 21, 2008 06:02PM
Thanks for all your Help. I think I'll do some tinkering and see what I can come up with.
Anthony
