A couple of days back I intended to upgrade my mendel prusa1 printer by removing the extroder motor from the carrage.
After the mechanical change I installed every thing back but the extruder motor doesn't work.
Even worse if I try to extrude the complete printer stalls and I have to disconnect the reset everything. The motor recives power but doen't turn (also not by hand at this point), like both spools get power at the same time.
I have tried anonther motor without result.
I have tried to switch 2 polulo's but the problem stays at the extruder
In the arduino software I switched the pins from extruder E0 to E1 but the problem shifts also.
I have no idea how to get it working again so any help will be greatly accepted.
grtz Marc
Edited 1 time(s). Last edit at 01/26/2013 07:54AM by MarcD.
