Best Belt-Less RepRap and Printer Designs (Rack & Pinion Rostock confused smiley)
Posted by Idolcrasher
February 02, 2013 06:32PM
Hi All,
I would like to get your input.
What are the best printer (or even independent axis) designs out which do not use belts?
I am weary of stretching, sagging belt slop decreasing my print quality over time.
I have been considering trying to custom build a rack & pinion Rostock or i3 Prusa; but before I go off trailblazing on some wild tangent, I thought I would see if anyone else is taking revenge on belts at the moment.
Thanks for your thoughts
FabberForge - Printing Happiness
[www.fabberforge.com]
Re: Best Belt-Less RepRap and Printer Designs (Rack & Pinion Rostock confused smiley)
February 02, 2013 08:50PM
Rack and pinion has been done before by at least 3 people. No word on if the print quality is better. I would think that the meshing of the gear teeth would need to be very good, otherwise you would get artifacts in the print. This means you would need "real" tooth profiles, not simplistic triangles. Good tooth profiles are non-trivial to generate from scratch.
February 02, 2013 09:00PM
I've thought about this too. I've been looking for an application for a rack and pinion system I've seen, though you may not like it... It uses belts! [bell-everman.com] and a video [m.youtube.com]
You could build a Rostock with the motors on the carriage using this system. It was always a bit to cumbersome for fitting on a normal reprap, but could work well on a Rostock. I understand that lots of CNC machines are going over to rack and pinion, and some to systems similar to this, too.
February 02, 2013 11:04PM
Belts are just... missing a certain je ne sais quoi
They just don't really feel like a GREAT idea... They work... But do they work great?
I suppose it depends on your definition of work great.
But man, when trying to calibrate the movement of a hot-end within sub-fractions of millimeters belts just leave much to be desired.
I know that belts are cheaper than a lot of fancier solutions... but I think I am done with them.
February 02, 2013 11:07PM
@Droftarts That belt application looks cool. It looks like they are going out of their way to compensate for traditional belt problems smiling smiley
Edited 1 time(s). Last edit at 02/02/2013 11:21PM by Idolcrasher.
February 03, 2013 02:32AM
Steel wire has to be the way to go. It doesn't stretch (normally) and is flexible enough to do a couple of turns around the drive motor.
_________________________________________________________________________________________
Richmond, New Zealand
Thingiverse ~ YouTube
February 03, 2013 06:51AM
Don't overlook the use of Spectra fishing line, it's working well on Tantillus and Rostock based machines. It's easy to tension and seems to stay very tight, I only have about 80 hours printing on Tantillus but they still ping without having any further adjustment from initial setup.
I can't imaging belts working as well for small machines like Tantillus. I have stretched and damaged enough belts over the years to really appreciate the use of Spectra line.
I believe more recent Sumpod machines have a rack and pinion system, if that's the way you want to go.
[richrap.blogspot.com]
February 03, 2013 10:10AM
Until you realize it has a minimum bend radius that has to be respected, or it will fatigue and break very rapidly.
For a steel wire strong enough to carry the tension loads we typically put on our belts, the minimum bend radius is in excess of 1.5 inches. And when you add in a reasonable factor of safety, the bend radius was in the neighborhood of 2 inches.
Now, this was for common steel cable. I imagine if you cared to get into more esoteric designs you could find something with a small BR and high load capacity... But then you run into availability issues, cost issues, etc.
My conclusion, in the end, was spectra beats out steel cable. In addition to the above, it's cheaper, it's safer, and it's easier to work with.
February 03, 2013 10:59AM
torqspline from Roton maybe? I made a sample axis and it moves quickly. Unless you use anti-backlash nuts, the frequency of steps at the end of moves is heard. [www.youtube.com] TrinityLabs has screws working on their production printer.
ball screws? there are plenty of fast lead screws to get speeds up. Not too much more expensive than belts and aluminum pulleys.
You can avoid those costly end bearing parts with a little ingenuity.
I don't like rack/pinion, and not sure why. Someone did a Prusa with printed up rack/pinion for the X and Y. Bulky but did work.
I did consider/purchase spectra and steel line for my large Ultimaker styled machine. Went with XL belts in the end.
Didn't want to lace it up and worried about long term breaks.
There needs to be someone working on cost reducing the linear stepper/linear bearing concept. Just the block moves and coils are charged to create movements. Scientific and assembly line equipment uses them. Usually paired with linear encoders for feedback also.
[www.intellidrives.com]
February 03, 2013 11:06AM
What's are the best sources in the web for learning how spectra fishing line setups are put together?
February 03, 2013 11:19AM
found a video explaining the fishing wire on a Kossel Fishing Line Explanation
Edited 1 time(s). Last edit at 02/03/2013 03:21PM by Idolcrasher.
February 03, 2013 12:05PM
Where are STLs for fishing line motor and idler ends? (As seen in that video)
Those could be used on any RepRap.
February 03, 2013 03:15PM
[github.com]
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing.
Anyone can edit the wiki!
February 03, 2013 03:22PM
Is the printed clamp used in that video there as well?
February 03, 2013 03:23PM
unfortunatley, from the video I can't really tell how the fishing line goes through the tensioner or how it is being tighter with a screw driver
February 03, 2013 03:28PM
Are there any adapted Prusa esque designs using fishing line out there?
February 03, 2013 09:17PM
I'm really surprised that a hardened steel and metal bushing setup is not more popular here... It has almost as little friction as bearings and less slop than LM8UUs and regular smooth rod... And is lighter as well...
As far as the drive for axis, I really think belts are the way to go. I'm not sure what people have against them, they can be very accurate when used properly.
Edited 1 time(s). Last edit at 02/03/2013 09:23PM by xclusive585.
February 04, 2013 10:03AM
a great plastic bushing is from Igus, called iGlide, and about $1.50 each for 8mm diameters. The J material or G are both good.
They have CAD models online and discounts for quantity orders.
They've also got an aluminum rod, precision ground, really straight and light. AWM shafts work with J.
February 04, 2013 08:43PM
I did find the bushings to be smoother than the linear bearings. However, they are less tolerant of off-axis loads in that they are more inclined to jam or stick and enter "stick-slip" motion.
My main problem with belts is that they are rather expensive and difficult to source. And you either need to have toothed idlers or run the smooth side of the belt over the idler in order to eliminate the tooth artifacts from prints.
February 05, 2013 04:20AM
How about Synchromesh?
[www.thingiverse.com]
I kinda want to try them out in my next printer project.
February 05, 2013 08:38AM
According to an applications engineer at SDP-SI, synchromesh is not a good choice for our application because it is not anit-backlash like GT2 belts are.
If you want more details you'll need to poke into the IRC and ask around - I wasn't the person who asked SDP-SI, and my memory on who did is a bit fuzzy.
February 05, 2013 11:34AM
Synchro mesh looks pretty cool smiling smiley
I use GT2 Belts and they stretched on me over 3-4 months.
Are they done stretching? Maybe?
Would I prefer a product that does not stretch at all? Certainly.
February 05, 2013 11:50AM
> months.
> all? Certainly.
How much did it stretch? I haven't witnessed any myself in over a year and I have used steel wire belts as well as more flexible (and more common) PU fibers. Perhaps you have them significantly over tensioned.
February 05, 2013 09:09PM
> project.
> GT2 belts are.
> fuzzy.
I think I might have heard that before. And I think I've heard of counter-arguements that they are a good fit for our application. Seeing the website, it seems to be specifically designed for small belt driven machines.
[sdp-si.com]
Also, how on earth do u design anti-backlashing into a belt? I don't see how mechanically superior can a GT2 belt be. At least in terms of handling backlashing.
Edited 1 time(s). Last edit at 02/05/2013 09:31PM by Pazu.
February 05, 2013 10:14PM
Disclaimer: I'm not a belt engineer, this is my understanding which could certainly be flawed.
It has to do with the tooth profile, and how the teeth on the belt engage with the pulley. This is why GT2, with its semicircular teeth, is superior to T5, with its larger and trapezoidal teeth.
Keep in mind there is a difference between what T5 was designed for - light duty power transmission, where positional accuracy is not extremely important, and what we need for our printers. For us, positional accuracy is paramount, so any slop in the teeth paying on or off the pulley when the motor reverses direction is not desirable.
My interpretation is that synchromesh is designed more as a replacement for T5 than for GT2.
And before anyone objects - yes, you can get good results from T5 belts. But you end up applying so much tension it basically acts like a piece of cable - the teeth are no longer what keeps the belt from slipping, friction is.
February 06, 2013 02:58AM
@crispy1, quite right you are. I found the some info here
[reprap.org]
Anyway, Synchromesh is interesting enough for me to give it a try.
February 06, 2013 09:54AM
For anyone interested in fast lead screws: I have contacted Igus about theirs because their online calculator showed extremely short service life (the screw nuts would wear out after some few prints). The representative explained to me that wear indeed is quite high the higher the lead gets and that these leadscrews certainly would not fit our applications.
The good news: There is another manufacturer located in the UK: Reliance Precision Mechatronics. I don't exactly know what they do differently, but some of their leadscrews are rated for up to 7000km service life, which would last some years even if one were to print one medium sized to large object per day.
What I would do about belt stretch is to take broader belts or to build a pulley system that also doubles your theoretical resolution while putting less strain on your belt.
February 07, 2013 09:25PM
Fast lead screws seem like a sound idea if the service life is long enough smiling smiley
February 07, 2013 09:58PM
@ uGen and Idolcrasher, Re: leadscrews
Have you guys been living under a rock? :-P
[trinitylabs.com]
[trinitylabs.com]
[trinitylabs.com]
and
[trinitylabs.com]
Edited 1 time(s). Last edit at 02/07/2013 09:59PM by crispy1.
February 07, 2013 10:17PM
Yes.
Must use these on the next printer, wonder if they are as good as they claim.
