Tame your spool with a little heat February 04, 2013 03:51AM |
Re: Tame your spool with a little heat February 04, 2013 05:02AM |
Re: Tame your spool with a little heat February 04, 2013 05:08AM |
Admin Registered: 13 years ago Posts: 1,063 |
Re: Tame your spool with a little heat February 05, 2013 03:14AM |
Re: Tame your spool with a little heat February 05, 2013 04:27AM |
Admin Registered: 18 years ago Posts: 14,148 |
Re: Tame your spool with a little heat February 05, 2013 04:34AM |
Re: Tame your spool with a little heat February 05, 2013 04:46AM |
Re: Tame your spool with a little heat February 05, 2013 07:37AM |
Re: Tame your spool with a little heat February 05, 2013 07:41AM |
martinprice2004
If you are only looking for about 80 degC then how about boiling water poured over it in a tub.
I think the idea was to REMOVE moisture and not ADD IT!|
Re: Tame your spool with a little heat February 05, 2013 07:56AM |
Re: Tame your spool with a little heat February 05, 2013 12:58PM |
Re: Tame your spool with a little heat February 06, 2013 02:20AM |
Re: Tame your spool with a little heat February 08, 2013 01:42PM |
