Power Supply correct one
Posted by scubi
February 12, 2013 06:50AM
HI
I am building a Prusa Air 2 with Hot bed.
Could you tell me if this specs are correct for the power supply I am buying :
PSU ENC i=88/264 [email protected]
Power supply Aluminium inclosed
320 Watts, 12 VDC @ 25AMP Closed Frame
Thanks
Vaughan
http://www.mantech.co.za/Stock.aspx?Query=power+supply+ENC+12vand]Power supply[/url]
Re: Power Supply correct one
February 12, 2013 10:11AM
Should be more then enough I'd think. I think its about 15A needed, but you always want some overhead.
February 12, 2013 11:42AM
Ya your good. About 11 amps is the minimum but like He said you definitely need some overhead. Otherwise you will have inaccurate bed and nozzle temps. Your power supply is perfect from what I can tell.
--------------| For Everything |--------------------------
Check it out here:
[reprapsquad.wordpress.com].
---------| For Everything Prototype Related |------
Now featuring comp case mods:
[RepRapLab.wordpress.com]
--------------| Find us at Twitter|------------------------
@REPRAPSQUAD (RS Main)
[mobile.twitter.com]
@REPRAPSQUADHQ (ProtoLab)
February 12, 2013 05:22PM
The one you are looking at looks OK but I wouldn't go any smaller - 30 amps is better if you are running a heated bed.
_________________________________________________________________________________________
Richmond, New Zealand
Thingiverse ~ YouTube
February 13, 2013 01:30AM
HI Guys
Thanks for your replies, really appreciate it. Now feel confident to buy it.
